A simple shell for pyboard
HermannSW
Re: A simple shell for pyboard
Post by HermannSW » Fri Nov 02, 2018 1:29 am
Oh wow!
I knew already that MicroPython is cool ...
Today I learned how to redirect stdout to a bytearray in this posting:
viewtopic.php?f=2&t=5446&p=31594#p31594
I wanted to use that for *nix like command line pipe operators between more than one upysh commands.
After I learned how to use StringIO, that it is available in MicroPython and that initialization with bytearray is possible all looked good.
Then I had to learn how to prevent a function with args to run when passed as arg to another function, and learned about lambda.
I only enabled head() for pipeing, just as a proof of concept -- still unbelievable to me how easy this can be done:
>>> cat("tst.txt")
first
second().
ThirD
  Fourth()
>>> head(lambda: tail("tst.txt", 3), 2)
second().
ThirD
>>> head("tst.txt", 2)
first
second().
I used the DUP class from the other posting, and stuffed all else into new function openlambda:
  • returns StringIO containing function output in case of lambda passed
  • returns open(f) in case of filename passed
I really like this, this is the small diff, here the DIP class from the other posting:
$ diff upysh.py upyshlambda.py
139a140,165
> from io import IOBase
> from io import StringIO
> class DUP(IOBase):
>     def __init__(self, s):
>         self.s = s
>     def write(self, data):
>         self.s += data
>         return len(data)
>     def readinto(self, data):
>         return 0
> def openlambda(f)
And this is openlambda():
> def openlambda(f):
>     if type(f) == type(lambda: x):
>         s = bytearray()
>         prev = os.dupterm(DUP(s))
>         f()
>         os.dupterm(prev)
>         return StringIO(s)
>     else:
>         return open(f)
141c167
<     with open(f) as f:
>     with openlambda(f) as f:
P.S:
Originally i wanted to enable pipeing for head(), tail(), wc(), grep(), od() and perhaps cat().
Just realized that "cp(lambda: tail('tst.txt', 3), 'newfile')" would make sense as well for "tail -3 tst.txt > newfile" ...
HermannSW
Post by HermannSW » Fri Nov 02, 2018 4:51 pm
Its done, with commit 4abab1e lambda pipeing has been added to 7 upysh commands:
>>> man
upysh is intended to be imported using:
from upysh_ import *
To see this help text again, type "man".
upysh commands head/cat/tail/wc/cp/grep/od allow for lambda pipeing:
  >>> tail(lambda: head('tst.txt', 3), 2)
  second().
  ThirD
upysh commands:
pwd, cd("new_dir"), ls, ls(...), head(...), tail(...), wc(...), cat(...),
newfile(...), mv("old", "new"), cp("src", "tgt"), rm(...),
grep("opt", "regex", "file"), od("opt", "file"), mkdir(...), rmdir(...), clear
upysh RAM usage increased by another 512 bytes to 6880, but it is definitely worth it.
Find more pipeing examples in fork-mission-statement. I only want to show this one from there:
od() allows to debug arbitrary stuff. With it issue #4285 was found and reported:
>>> od('c', lambda: sys.stdout.write('abc'))
000000   a   b   c
        61  62  63
000003
P.S:
Pipeing grep is helpful in looking into interned string usage:
>>> micropython.qstr_info()
qstr pool: n_pool=1, n_qstr=61, n_str_data_bytes=461, n_total_bytes=2077
>>> grep('', 'tst', lambda: micropython.qstr_info(1))
Q(tst.txt)
Q(tst)
pfalcon
Post by pfalcon » Fri Nov 02, 2018 10:03 pm
Cool, but not nearly as cool as https://pypi.org/project/pipeto/
Awesome MicroPython list
HermannSW
Post by HermannSW » Fri Nov 02, 2018 10:26 pm
The vertical bars look like the pipe original, but not the "done"s.
Compose looks good.
Does pipeto run on MicroPython?
HermannSW
Post by HermannSW » Sat Nov 03, 2018 8:29 pm
OK, I did "pip3 install pipeto" and all samples from the project link worked fine under python3.
Then I copied over pipeto.py and operator.py to ESP01s module.
The import of operator.py resulted in errors, these were the differences I had to make to keep MicroPython happy:
$ diff operator.py.orig operator.py
110c110
<     return a @ b
>     return a # @ b
377c377
<     a @= b
>     a # @= b
After those changes importing pipeto was fine, but importing operator afterwards runs out of memory:
$ webrepl_client.py -p abcd 192.168.4.1
Password:
WebREPL connected
MicroPython v1.9.4-272-g46091b8a on 2018-07-18; ESP module with ESP8266
>>> gc.collect(); gc.mem_free()
28640
>>> from pipeto import *
>>> import operator as op
MemoryError: memory allocation failed, allocating %u bytes
OK, pipeto only needs the "or" operator, so I minimized operator.py for pipeto usage:
$ cat operator_.py
def or_(a, b):
    "Same as a | b."
    return a | b
__or__ = or_
Now importing pipeto and minimized operator_ works fine, does cost 1360 bytes RAM ...
Password:
WebREPL connected
>>> gc.collect(); m0=gc.mem_free()
>>> import operator_ as op
>>> gc.collect(); m1=gc.mem_free()
>>> print(m0, m1, m0-m1)
28624 27264 1360
... and all the examples from pipeto project page work like a charme with MicroPython:
>>> inc = lambda x: x + 1
>>> double = lambda x: x + x
>>> pipe(1) | float | str | list | done
['1', '.', '0']
>>> pipe(2) | inc | done
3
>>> pipe(2) | inc | double | done
6
>>> pipe([1,2,3]) | sum | done
6
>>> newfn = compose(inc) | double
>>> newfn(2) # == double(inc(2))
6
A trivial upysh_ sample works with pipeto:
>>> wc_ = lambda x: wc(x)
>>> pipe('boot.py') | wc_ | done
16 37 361 boot.py
The 1st function arg is passed by pipeto "self.val = fn(self.val)":
class _Pipe(object):
    def __init__(self, val):
        self.val = val
    def __or__(self, fn):
        if fn == done:
            return self.val
        return self
def pipe(arg):
    return _Pipe(arg)
def done(arg):
    return arg
Since head() command has 2 args, I need to find a way to pass the second arg.
Simplified the problem is starting with this simple example ...
3
... the enhanced lambda with two args works:
>>> inc2 = lambda x,y: x + y
>>> inc2(3,4)
7
Not sure how to pass second arg with pipeto, any hints welcome:
>>> pipe(3) | inc2 ??4?? | done
HermannSW
Post by HermannSW » Sat Nov 03, 2018 10:07 pm
I had to learn more Python, especially the "*" operator for converting tupel to function args.
It turned out to be really easy:
  • do "... | fn | ..." for function fn with 1 (piped) arg
  • do "... | (fn, arg2, arg3, ..., argN) | ..." for function fn with N args, 1st arg piped
Here you can see little MicroPython multi arg function pipe demo, it works:
>>> from pipe_ import *
>>> inc  = lambda x: x+1
>>> inc3 = lambda x,y,z: x+y*z
>>> inc3(4,5,6)
34
>>> pipe(4) | inc | done
5
>>> pipe(4) | (inc3,5,6) | done
34
And this is the simple module that does it:
$ cat pipe_.py
        self.val = val
        if fn == done:
            return self.val
        elif type(fn) == type( (0,) ):
            self.val = fn[0]( * (self.val,) + fn[1:] )
        return self
def pipe(arg):
    return _Pipe(arg)
def done(arg):
    return arg
def or_(a, b):
    "Same as a | b."
    return a | b
__or__ = or_
The trick was to add
to _Pipe class member function __or__!
I can now fully understand pfalcon's previous statement wrt my lambda pipeing implemented for 7 upysh_ commands:
Now I need to find the correct way to make use this exciting pipeing feature with upysh_ commands.
P.S:
This is first simple (and wrong) multi arg upysh head() command demo.
What is wrong is that head() command outputs to stdout, instead of pipeing and letting "done" do the output:
>>> head_ = lambda f,n: head(f,n)
>>> pipe('tst.txt') | (head_,3) | done
first
second().
ThirD
HermannSW
Post by HermannSW » Sat Nov 03, 2018 11:59 pm
I wanted to get rid of the "head_" lambda definition for using head() function in pipes.
Because the 7 functions I want this to have for are easy, no inspect module is needed.
I looked up what to take from that module for upysh_ command application.
Here is use of new function L(fn) taking function as input:
>>> pipe('tst.txt') | (L(head),3) | done
first
second().
ThirD
L(fn) takes function fn, determines the variables passed, and then returns exactly the lambda I previously created by hand and assigned to "head_". This is another "oh wow" for me:
def L(f):
    vs=f.__code__.co_varnames[:f.__code__.co_argcount]
    return lambda *vs: f(*vs)
P.S:
I should got to sleep now -- while L(fn) is correct and cool on its own, it is not needed!
Instead of passing "head_" as earlier, or L(head), just pass "head" and that's it:
>>> pipe('tst.txt') | (head,3) | done
first
second().
ThirD
>>> pipe('tst.txt') | (tail,3) | done
second().
ThirD
  Fourth()
Works for builtin functions as well:
>>> pipe(-6.3) | abs | done
6.3
HermannSW
Post by HermannSW » Sun Nov 04, 2018 1:37 pm
I don't know why pipeto project did import operator module, it is not needed for pipes at least, and removed.
"done" can be any function, is not executed, so I replaced it with minimal function.
I added "__str__" Pipe_ class member, that allows to get all more "shell pipe like" using print():
>>> from pipe_ import *
>>> pipe(-4) | abs | done
4
>>> print( pipe(-4) | abs )
4
Another example:
>>> def powt(t): return pow(*t)
>>> print( pipe(17) | (divmod,3) )
(5, 2)
>>> print( pipe(17) | (divmod,3) | powt )
25
Simplified and enhanced "pipe_.py" ...
        self.val = val
        if fn == done:
            return self.val
        return self
    def __str__(self):
        return self.val
def pipe(arg):
    return _Pipe(arg)
def done():
    return
HermannSW
Post by HermannSW » Sun Nov 04, 2018 8:21 pm
Using __str__() the way I did is not good. While MicroPython accepts it, CPython gives an error message:
>>> sys.version_info
sys.version_info(major=3, minor=4, micro=9, releaselevel='final', serial=0)
TypeError: __str__ returned non-string (type int)
As preparation for more pipeing work commit 5085e56 moved file arg to 1st arg of grep() and od() commands. The option string moved to last position for both, with an empty string default:
>>> grep('tst.txt', 't')
first
  Fourth()
>>> grep('tst.txt', 't', 'i')
first
ThirD
  Fourth()
HermannSW
Post by HermannSW » Tue Nov 06, 2018 1:19 am
I made huge progress, integrated the reduced pipe_ module (minus the __str__() member function) into upysh, and made pipe work. This time it is real pipe, that is nothing gets written (as duplicate) to sys.stdout as with lambda pipeing before (lambda pipeing is fine with webrepl.html in browser or webrepl_client.py, but screen session shows all the duplicated lines which is disturbing).
Current upysh.py cannot be imported on ESP8266 anymore because running into out of memory -- temporarily after import 17KB RAM is needed, but gc.collect() shows that really only 8304 bytes are needed:
>>> m1=gc.mem_free()
>>> gc.collect(); m2=gc.mem_free()
>>> print(m0,m1,m2,m0-m1,m0-m2)
100944 84016 92640 16928 8304
First, I enhanced what was there, so now both pipeings work.
The most trivial new pipe consists of pipe() with filename and done.
The filename passed to pipe() opens file that is read and printed by done:
>>> pipe("tst.txt") | done
first
second().
ThirD
  Fourth()
I have implemented new pipeing for head() and tail() as proof of concept.
While new pipeing is fine, the result for lambda pipeing now needs an additional step:
>>> pipe("tst.txt") | (head,3) | (tail,2) | done
second().
ThirD
>>> print( tail(lambda: head("tst.txt",3), 2)  .getvalue(),end="")
second().
ThirD
New _Pipe class __init__() prepares the file to be processed first:
        self.val = open(val)
_Pipe class __or__() remains mainly the same, only done handling changed:
        if fn == done:
            if type(self.val) == TextIOWrapper:
                print("".join(self.val.readlines()),end="")
                return
            elif type(self.val) == StringIO:
                print(self.val.getvalue(),end="")
                return
                return self.val
_openlambda() keeps being called as before, only this has been inserted to myke new pipeing work:
    elif type(f) == TextIOWrapper or type(f) == StringIO:
        return f
This is slightly modified head() function:
def head(f, n=10):
    out = sys.stdout if type(f) == str else StringIO(bytearray())
    with _openlambda(f) as f:
        for i in range(n):
            l = f.readline()
            if not l: break
            out.write(l)
    if out != sys.stdout:
        out.seek(0,0)
        return out
The first and last 3 lines (needed for all upysh commands) look like they can be done as a decorator, but not a simple one.
Instead of always sending output to sys.stdout, now in case of pipeing output gets written into StringIO, which finally gets seeked to first position before returned as input for next pipe command.
This just describes what is there currently, memory on input needs to be brought down, decorators need to be implemented if possible, perhaps the whole lambda pipeing needs to be removed, ...
P.S:
I just removed the lambda pipeing stuff, and now it fits into ESP8266 as well, finally needing 7424 bytes RAM:
>>> m1=gc.mem_free()
28656 13136 21232 15520 7424
second().
ThirD
P.P.S:
>>> pipe("tst.txt") | (head,3) | (tail,2) | (grep,'t','i') | done
ThirD
