A simple shell for pyboard
HermannSW
Re: A simple shell for pyboard
Post by HermannSW » Wed Nov 07, 2018 11:35 pm
From current help():
upysh commands:
pwd, cd("new_dir"), ls, ls(...), head(...), tail(...), wc(...), cat(...),
newfile(...), mv("old", "new"), cp("src", "tgt"), rm(...), clear
grep("file", "regex" [, "opt"]), od("file" [, "opt"]), mkdir(...), rmdir(...)
Analyzing which commands can be pipe generator/consumer (of generator|consumer) gives:
          none:  pwd, cd(), newfile(), mv(), rm(), clear, mkdir(), rmdir()
generator only:  man, ls, ls()[, pipe(filename)]
          both:  head(), tail(), cat(), grep(), od()
 consumer only:  wc(), cp()[, done]
Commands missing that could be useful (all for "both"): cut() -b, sort() -r/-n, uniq() -c/-u
HermannSW
Post by HermannSW » Thu Nov 08, 2018 12:17 am
After previous removal of lambda pipeing code, the previous use of "cp(lambda: head('tst.txt',3), 'x')" as "head -3 tst.txt > x" is not possible anymore. Pipeing cp() now leaves a Pipe_ class object:
>>> pipe("tst.txt") | (cp,"x")
<_Pipe object at 3fff1ae0>
Therefore cp() has been changed (in streaming mode) to be the "tee" command:
>>> pipe("tst.txt") | (head,3) | (cp,"3.txt") | (tail,2) | done
second().
ThirD
>>> cat("3.txt")
first
second().
ThirD
This is current cp():
def cp(s, t):
    S = _openlambda(s)
    with open(t, "w") as t:
            l = S.readline()
            if not l: break
            t.write(l)
    if type(s) != str:
        S.seek(0,0)
        return S
HermannSW
Post by HermannSW » Thu Nov 08, 2018 12:48 am
I remembered the usecase of "micropython.qstr_info()" output being processed by grep() [or sort(), uniq()].
I had to bring in back lambda processing, but this time only in pipe() arg:
>>> import micropython
>>> pipe(lambda: micropython.qstr_info(1)) | (head,5) | done
qstr pool: n_pool=1, n_qstr=65, n_str_data_bytes=494, n_total_bytes=2110
Q(webrepl_cfg.py)
Q(abcd)
Q(upysh_)
Q(upysh_.py)
In class _Pipe(object):
    def __init__(self, val):
        if type(val) == type(lambda: x):
            s = bytearray()
            prev = os.dupterm(_DUP(s))
            val()
            os.dupterm(prev)
            self.val = io.StringIO(s)
            self.val = open(val)
P.S:
This lambda processing alllows to grep "ls" and "man" command output:
>>> pipe(lambda: print(man)) | (grep,"grep") | done
upysh commands head/cat/tail/wc/cp/grep/od allow for lambda pipeing:
>>> pipe(lambda: print(ls)) | (grep,"\d\d\d\d\d") | done
   12353 upysh_.py
>>> pipe(lambda: print(ls)) | (grep,"^   \d") | done
   12353 upysh_.py
HermannSW
Post by HermannSW » Thu Nov 08, 2018 1:52 am
I solved the out of memory error on import into ESP8266(ESP-01s) MicroPython which became real again after latest additions. It seems that doing lazy import of normally unneeded stuff is the solution to help MicroPython being able to import. The big arrays _0 and _1 are only needed when wc() command gets executed, and splitting them away into module "wc.py" resolves the issue completely!
MicroPython v1.9.4-272-g46091b8a on 2018-07-18; ESP module with ESP8266
>>> m0=gc.mem_free()
>>> from upysh_ import *
>>> pwd
>>> m0, gc.mem_free()
(26464, 22192)
>>> wc("tst.txt")
4 4 33 tst.txt
>>> gc.mem_free()
19520
This is split module:
$ cat wc.py
import array
a0=array.array('H', [32, 126, 159, 887, ...
a1=array.array('H', [11, 12, 38, 39, 58, ...
And this is the wc() code initializing the two global variables _0 and _1 that have values None before executing wc() for the first time:
def wc(fn):
    global _0
    global _1
    if _0 == None:
        import wc
        _0 = wc.a0
        _1 = wc.a1
    out = sys.stdout if type(fn) == str else io.StringIO(bytearray())
    with _openlambda(fn) as f:
        c=r=w=0
            l = f.readline()
            if not l: break
            r=r+1
            c=c+len(bytes(l,'utf-8'))
            w=w+words(l)
    out.write("{0:d} {1:d} {2:d} {3:s}\n".format(r,w,c,fn))
    if out != sys.stdout:
        out.seek(0,0)
        return out
P.S:
upysh.py runs fine with "from upysh.py import *" in python3.
Use of "io.StringIO(bytearray())" results in this error message in python3:
TypeError: argument should be string, bytes or integer, not _io.StringIO
I replaced all occurences by io.StringIO('') and now it works in MicroPython as well as in python3.
Only upysh.py feature I found sofar that does not run in python3 is pipe() lambda evaluation, because os.dupterm() is unknown.
HermannSW
Post by HermannSW » Sun Nov 11, 2018 9:33 pm
I completed the pipeing work for all commands affected, and updated man as well as README.txt fork-mission-statement:
https://github.com/Hermann-SW/micropyth ... -statement
Now RAM usage is 6352 byte as long as "wc()" command does not get used. That command does lazy import of split out module "words.py". On ESP-01s even that runs out of memory because temporarily the import does need too much RAM. For such systems preloading words.py before importing upysh_ works. Both modules together need 8880 bytes of RAM:
>>> gc.collect(); m0=gc.mem_free()
>>> import words
>>> gc.collect(); m1=gc.mem_free()
>>> print(m0, m1, m0-m1)
28656 19776 8880
"tee()" command has been added in addtion to "cp()" command.
New pipeing based on parts of pipeto 0.2.1, with added multi argument processing, is available.
From upysh_ man:
Most upysh_ commands allow for "producer|consumer" pipeing:
  >>> pipe("tst.txt") | (head,3) | (tee,"3.txt") | (grep,'t','i') | done
  first
  ThirD
  >>> pipe(lambda: micropython.qstr_info(1)) | (head,2) | done
  qstr pool: n_pool=1, n_qstr=69, n_str_data_bytes=525, n_total_bytes=2141
  Q(webrepl_cfg.py)
producer only:  man, ls, ls()[, pipe()]
         both:  head(), tail(), cat(), grep(), od(), tee()[, wc(), cp()]
consumer only:  [done]
You can install "normal" upysh and upysh_ with words.py on a module. If ever memory consumption of upysh_ becomes a problem, just do CTRL-D soft reset and use upysh.
Have fun with upysh_ pipeing ...
>>> pipe(lambda: ls()) | (grep,'^    [0-9]') | done
    6633 upysh_.py
    5543 wc.py
    6464 words.py
HermannSW
Post by HermannSW » Tue Nov 13, 2018 8:02 pm
I went a step further, not more features for upysh_ yet, but being able to execute a single MicroPython command remotely for being able to use all the Linux bash shell power for working on single command MicroPython output.
Here is a first simple sample, just demonstrating what it is:
$ ./micropython mp.py 192.168.4.1 5**4**3
542101086242752217003726400434970855712890625
In this posting I did describe how to remote control MicroPython from another MicroPython, using Danni's uwebsocket module. I tried to make use of that with python3, and after many changes to get uwebsocket module (because that is much easier to use than my webrepl_client.py python[23] remote console) to run with python 3 I ended up with this python3 error on difference to MicroPython:
$ python3 echo_websocket_org.py
  File "echo_websocket_org.py", line 2, in <module>
    websocket = client.connect("ws://echo.websocket.org/")
  File "/home/stammw/uwebsockets/client.py", line 59, in connect
    header = sock.readline()[:-2]
AttributeError: 'socket' object has no attribute 'readline'
I gave up there and remembered on the unix port of MicroPython. With it uwebsockets module new echo_websockets_org.py example directly worked:
$ ./micropython
MicroPython v1.9.4-683-gd94aa57 on 2018-11-13; linux version
>>> import echo_websocket_org
The quick brown fox jumps over the lazy dog
At the start of this posting I already showed mp.py in action. It is running in unix port MicroPython, uses uwebsockets module to connect to ESP-01s WebREPL with IP address 192.168.4.1 and executed the passed command. Before I show the simple 25 line only mp.py, I will show the intended application (of mixing Linux bash, unix port MicroPython and ESP8266 MicroPython alltogether).
First my upysh_ module needs to be imported, after the ESP-01s was powered on (the quotes around star character are needed to prevent bash from expanding it):
$ ./micropython mp.py 192.168.4.1 from upysh_ import '*'
upysh_ is intended to be imported using:
[import words  (on systems with very small RAM)]
grep(file, regex [, opt]), od(file [, opt]), mkdir(...), rmdir(...)
Now that upysh_ module is loaded, its "ls" command can get executed on ESP-01s (that sorts files alphabetically), and Linux bash can be used to sort by size. This should just be a simple example:
$ ./micropython mp.py 192.168.4.1 ls | sort -n
       0 empty
      11 umlaute.txt
      14 webrepl_cfg.py
      23 rn.txt
      29 numstr.txt
      33 tst.txt
      60 tloop.py
     361 boot.py
     384 256.dat
    1571 upysh.py
    6464 words.py
    6633 upysh_.py
Now that you have seen how to use mp.py in unix port MicroPython, here it is:
import uwebsockets.client
import sys
websocket = uwebsockets.client.connect('ws://'+sys.argv[1]+':8266/')
def do(cmd,out=True):
    inp = cmd+"\r\n"
    websocket.send(inp)
    resp = ""
    while not("\n>>> " in resp or resp.startswith(">>> ")):
        resp = websocket.recv()
        while inp != "" and resp != "" and inp[0] == resp[0]:
            inp = inp[1:]
            resp = resp[1:]
        if out and not("\n>>> " in resp or resp.startswith(">>> ")):
            print(resp,end='')
assert resp == "Password: ", resp
do("abcd",False)
do(" ".join(sys.argv[2:]))
So for doing a MicroPython session I will use upysh_ on the module itself, in a webrepl_client.py remote session.
And if more than the features and commands implemented in upysh_ is needed, I will use mp.py and Linux bash.
P.S: P.P.S:
This is mixed pipeing example. The mp.py command needs to be quoted for dividing the vertical bars between MicroPython upysh_ processing and Linux bash shell:
$ ./micropython mp.py 192.168.4.1 'pipe(lambda: micropython.qstr_info(1)) | (tee,"qstr.txt") | done' | sort | tail -6
Q(v)
Q(wc)
Q(webrepl_cfg.py)
Q(wloaded)
Q(words)
Q(x)
If teeing output into qstr.txt is not needed, the command line looks much easier:
$ ./micropython mp.py 192.168.4.1 'micropython.qstr_info(1)' | sort | tail -6
Q(v)
Q(wc)
Q(webrepl_cfg.py)
Q(wloaded)
Q(words)
Q(x)
P.P.P.S:
For another application of mp.py see this posting (1000s of calls):
viewtopic.php?f=2&p=31863#p31863
