Page 1 of 2
picotui - Text User Interface (TUI) library for MicroPython (and CPython)
Posted: Fri Sep 02, 2016 2:55 pm
by pfalcon
I decided to split this from the previous topic:
viewtopic.php?f=15&t=669
picotui is lightweight, pure-Python Text User Interface widget toolkit with minimal dependencies. It's intended to be run with both MicroPython (unix port) and CPython3.
https://github.com/pfalcon/picotui
Below is a screenshot of what kind of UI can be created with picotui:
Re: picotui - Text User Interface (TUI) library for MicroPython (and CPython)
by pfalcon
The latest release, 0.8, adds initial support for menus.
Posted: Thu Sep 22, 2016 1:40 pm
by torwag
Hi pfalcon,
Since you wrote unix port I am confused here. Would this also run via an ssh/telnet session on a micropython board?
Posted: Thu Sep 22, 2016 1:57 pm
by pfalcon
I don't know, you can try and share your experiences. But this projects is on biggish side, intended to provide real-world usable UI, not run in very small heap. Folks interested in minimalistic implementation intended to run, and running, on boards, may follow the thread linked from the top message.
Posted: Fri Sep 30, 2016 7:10 am
by danielm
pfalcon, I wanted to try picotui on WiPy port, but the module uses decimal numbers as I did get following message:
>>> from picotui.context import Context
File "/flash/lib/picotui/context.py", line 1, in <module>
File "/flash/lib/picotui/screen.py", line 206
SyntaxError: decimal numbers not supported
Not sure if decimals are used in other places of the code. Do you think that the module could be rewritten with integers only?
Posted: Fri Nov 24, 2017 8:57 am
by pfalcon
Posted: Fri Nov 24, 2017 10:41 am
by Roberthh
Hi pfalcon,
I have used a subset of the picotui on ESP8266, just radiobuttons and simple text fields, for the configuration of an application. That works well. The full package is too large for the small heap, and even with the subset I had to run the Picotui and the other app alternatively. It did not work with webrepl. As soon as the picotui starts, the webrepl session is closed. I did not look into that further, since USB was sufficient in that case.
Posted: Sat Dec 09, 2017 10:04 am
by pfalcon
Posted: Sat Feb 17, 2018 11:23 am
by pfalcon
picotui 1.0 released:
https://pypi.python.org/pypi/picotui/1.0 . This release features refactorings and cleanups for technical debt accumulated, apps may need adjustments:
https://github.com/pfalcon/picotui/issu ... nge%22+1.0
Posted: Sat Feb 17, 2018 11:42 am
by Roberthh
Thanks. I'm using picotui in an application and it is a great help.
