Hello everyone,
I plan to buy 2 micropython boards and implement Commpy library to create a communications system between each other. Micropython can support this library? and if so, Can I use a analog or digital GPIO without any external board?
I appreciate your help!
Can I use Commpy library in micropython?
Re: Can I use Commpy library in micropython?
Do you have a link to the compy library?
You can also use serial, and CAN., I use a half-duplex serial that allows multiple devices to sit on a single wire bus.
Yes, http://veeresht.info/CommPy/
i am trying to implement a digital Communication protocol, by which I need to send more than 8 bits in every frame transmitted may be 1024 bits in every frame. I dont know if UART can works well with turbo coding or any other Error correcting code from Commpy library.
Can you give me a hint?
Kind regards,
Germán Ch.
Kind regards,
Germán Ch.
I was able to work only with SQL Alchemy and get your database schema, but now probably have to work with Commpy addition, I`ll be glad to know how ...
From a quick look at the docs Commpy looks like a complex library aimed at producing modulation signals for radio links. It depends on NumPy, SciPy and Matplotlib all of which are large libraries not ported to MicroPython. Microcontrollers require a different approach owing to their limited resources.
If you just want to communicate between two Pyboards the easy way is to use a UART. If you use the uasyncio library, UARTs can be accessed as stream devices like files. This makes communication quite simple.
