Help understanding ternary statement in py/objcomplex.c
BrendanSimon
Post by BrendanSimon » Fri Feb 03, 2017 10:39 am
I just saw this change in `py/objcomplex.c` (line 225). I have no idea what the ternary statement is supposed to do. Is it a bug or some unusual use of the conditional operator?
-                if (rhs_imag == 0) {
-                    lhs_real = 1;
+                if (rhs_imag == 0 && rhs_real >= 0) {
+                    lhs_real = 1 ? rhs_real == 0 : 0;
Doesn' the first expression `1` always evaluate to true, then the second expression is always executed?
What is the purpose of the third expression `0` ?
Is this equivalent to `lhs_real = true` or `lhs = false`, depending on the value of rhs_real ?
If so, why wouldn't it be written as: `lhs_real = (rhs == 0) ;
Is this some fancy way of assigning a boolean or an integer (by some magic) ?
And I thought I knew C ?[/color]
Re: Help understanding ternary statement in py/objcomplex.c
Post by deshipu » Fri Feb 03, 2017 10:58 am
Looking closer, it looks like a bug. Someone probably got confused with Python's "foo = bar if baz else boo" and got this wrong.
BrendanSimon
Post by BrendanSimon » Fri Feb 03, 2017 11:20 am
That's what I thought too -- that it was a Python ternary statement, but then double checked that it was a C file.
But the code I've seen in MicroPython looks very well written, so I assumed it was correct and purposeful (but even the really good programmers are fallible)
I also found this on stackoverflow (trying to find an answer) and it has a similar syntax, but it is about the type returned if both 2nd and 3rd expressions are pointers, which doesn't seem to apply in this case.
http://stackoverflow.com/questions/1409 ... ypecasting
Hopefully it's a bug, as it certainly isn't very clear (at least to me)
Online
stijn
Post by stijn » Fri Feb 03, 2017 1:05 pm
*edit* not sure if what I wrote was even correct and I can't be bother to lookup the standard rules atm
Post by pythoncoder » Fri Feb 03, 2017 1:22 pm
Agreed. It looks like an issue that should be raised on GitHub.
[EDIT]I see it was, a few minutes ago.
Post by deshipu » Fri Feb 03, 2017 1:24 pm
I think it was supposed to be:
if (rhs_real == 0) {
    lhs_real = 1;
} else {
    lhs_real = 0;
Which could of course be written much shorter:
lhs_real = !rhs_real;
