rshell - connecting my lopy board?
soerena
Post by soerena » Sat Mar 25, 2017 4:20 pm
Hello to you all!
After a huge amount of fuzzle with pycom's lopy to get it set up, I have come to the conclusion to not use their IDE "Pymakr" and rather try out rshell. I was though pretty quickly stopped by not having any clue how to connect my board via rshell.
the connect command's help method only says:
connect TYPE TYPE_PARAMS
connect serial port [baud]
connect telnet ip-address-or-name
I don't know what most of the parameters here mean. TYPE, and TYPE_PARAMS eg. I know what baudrate is, and IP-address-or-name obviously. Is there something I missed? An example or documentation that I couldn't find?
All the best
Søren
Re: rshell - connecting my lopy board?
Post by pythoncoder » Sun Mar 26, 2017 11:17 am
You haven't told us how you're connected and what OS you're using. If you're connected via USB you need to know the device name. On Linux you can issue
ls /dev/tty*
You'll probably find an entry like ttyACM0 or ttyUSB0 (I haven't got a PyCom board to test). Then all you need is
rshell -p /dev/ttyUSB0 --buffer-size=30
In my view rshell is the best way to access MicroPython targets.
TravisT
Post by TravisT » Tue Mar 28, 2017 6:09 pm
rshell works great with lopy and wipy. It its my main tool for those devices. I use FTP sometimes to manage a bunch of files but rshell recently added recursive copy, which I have not tested yet.
You might have to run this under sudo user if permissions gives you issues.
_______________
Travis Travelstead
Post by pythoncoder » Wed Mar 29, 2017 11:27 am
TravisT wrote:...You might have to run this under sudo user if permissions gives you issues.
This is often solved by adding yourself to the dialout group.
usermod -a -G dialout your_username
