python version of AnduinoWiFi to configure Wifi
Is there a python equivalent of: https://github.com/andium/Anduino/tree/ ... nduinoWiFi which would allow the configuration of SSID and password via a web-server running on a micropython board? I couldn't find one on github. If not, I could follow the webrepl code as a starting point.
Re: python version of AnduinoWiFi to configure Wifi
Here is an example solution: https://github.com/manningt/setwifi
This implementation assumes the module will be 'frozen' in flash, so the size is not critical. It can be used for initial deployment of a device, or it can be called if the WiFi network needs to be changed at a later time.
