Hello all micropython fans,
I have recently given a talk at PyCon CZ 2017 about a small fun project that runs micropython as one of freertos tasks. Except for the use case, that itself is interesting but not new, I would like to know everyone's opinions on the build/configuration solution.
The talk notes + slides: https://github.com/braiins/pycon2017-mi ... ater-notes
In brief, this whole project started after finding out that the 'make' based build system is able to perform qstr definition extraction (our proposal), but the solution is not convenient due to the way make detects what needs to be rebuilt (based on timestamps). At the same time I want more from the build system - simplified code generation, support for Kconfig etc. This
We have written (@braiins) a SCons tool called - PILA that does the job quite nicely.
The micropython branch with the new buildsystem added is here: https://github.com/braiins/micropython/ ... la-upy-1.8
Unfortunately, we have to figure out some licensing issues with our HAL that we are about to relase to general public sometime this week. At that point a simplified docker based build and configuration of the demo will be possible.
Kind regards,
Jan
PILA - Disrupting the buildsystem using SCons
braiins - Your partner in embedded world - http://www.braiins.cz
Re: PILA - Disrupting the buildsystem using SCons
Hi Jan,
any news about HAL release?
