I was using micropython library for my project with CoIDE with gcc tool chain.
There is no problem of compilation.
Later i shifted to Keil IDE with armcc tool chain.
But i have compilation errors in assembly code.
In micropython/py/nlrthumb.c file the following error message was thrown out
O
__attribute__((naked)) unsigned int nlr_push (nlr_buf_t *nlr) {
__asm volatile (
"str r4, [r0, #12] \n" // store r4 into nlr_buf
"str r5, [r0, #16] \n" // store r5 into nlr_buf
"str r6, [r0, #20] \n" // store r6 into nlr_buf
"str r7, [r0, #24] \n" // store r7 into nlr_buf
"str r8, [r0, #28] \n" // store r8 into nlr_buf
"str r9, [r0, #32] \n" // store r9 into nlr_buf
"str r10, [r0, #36] \n" // store r10 into nlr_buf
"str r11, [r0, #40] \n" // store r11 into nlr_buf
"str r13, [r0, #44] \n" // store r13=sp into nlr_buf
"str lr, [r0, #8] \n" // store lr into nlr_buf
"b nlr_push_tail \n" // do the rest in C
..\..\..\Micropython\py\nlrthumb.c(49): error: #549: variable "R0" is used before its value is set
..\..\..\Micropython\py\nlrthumb.c(49): error: #549: variable "R4" is used before its value is set
..\..\..\Micropython\py\nlrthumb.c(49): error: #549: variable "R5" is used before its value is set
It is throwing errors for all the lines.
Please help me to remove the compilation errors.
micropython assembly code compilation error with keil v5.18
