please, consider the following code
for foo in range(10):
--print(foo)
--for bar in range(10):
----pass
--else:
----continue
--break
in a full-blown python the result is a sequence of numbers 0 through 9, micropython terminates at number 0. i am not sure if this is a micropython implementation, known issue or something else but i wonder if anyone sees something similar.
micropython is v1.8.5 on esp8266.
weird behaviour breaking from a nested loop
Re: weird behaviour breaking from a nested loop
I can replicate this on the Unix build of MicroPython. I agree that the behaviour is wrong so it does appear that you've uncovered a bug. I'll raise an issue on GitHub.
[EDIT]
See https://github.com/micropython/micropyt ... -309975195
[EDIT]
This issues has been fixed in the latest version of the code.
