A Micro HTTP Web Server and language templating for MicroPython
jczic
Post by jczic » Fri Sep 01, 2017 2:48 am
Just if you want a Micro HTTP Web Server and language templating for MicroPython (used on Pycom modules) :
https://github.com/jczic/MicroWebSrv
loboris
Re: A Micro HTTP Web Server and language templating for MicroPython
Post by loboris » Fri Sep 01, 2017 9:30 pm
Thanks for the information.
I have included it with minor modifications into my MicroPython port as a frozen module and it works very well.
Are you planning to implement WebSockets protocol and posted multipart data mentioned in "issues" ?
rdagger
Post by rdagger » Sun Sep 03, 2017 11:39 pm
jczic wrote:Hello,
Your library looks great! Is it compatible with an ESP32? Have you tried implementing websockets?
Post by OutoftheBOTS_ » Sun Feb 04, 2018 9:48 am
@jczic
I am trying to get websockets to work on my ESP32 using your library.
I have tried all your examples and they work fine on the firmware I am using (laboris port)
This is the code that I tried to start the webserver and send websocket messages, I also have a htlm file in the flash/www/ directory that is for receiving the websockets message and display it on the screen.
I get the following error
AttributeError: 'MicroWebSrv' object has no attribute 'SendText'
with this code
from microWebSrv import MicroWebSrv
def _acceptWebSocketCallback(webSocket, httpClient) :
  print("WS ACCEPT")
  webSocket.RecvTextCallback   = _recvTextCallback
  webSocket.RecvBinaryCallback = _recvBinaryCallback
  webSocket.ClosedCallback     = _closedCallback
def _recvTextCallback(webSocket, msg) :
  print("WS RECV TEXT : %s" % msg)
  webSocket.SendText("Reply for %s" % msg)
def _recvBinaryCallback(webSocket, data) :
  print("WS RECV DATA : %s" % data)
def _closedCallback(webSocket) :
  print("WS CLOSED")
mws = MicroWebSrv()                                    # TCP port 80 and files in /flash/www
mws.MaxWebSocketRecvLen     = 256                      # Default is set to 1024
mws.WebSocketThreaded       = False                    # WebSockets without new threads
mws.AcceptWebSocketCallback = _acceptWebSocketCallback# Function to receive WebSockets
mws.Start()
t=0
  print(t)
  mws.SendText(str(t))
  time.sleep(1)
  t+=1
Post by OutoftheBOTS_ » Sun Feb 04, 2018 11:27 am
Ok I found the wstest.html and am playing with it now and it works.
I think that I maybe better understanding how it work. The server can only send a message in response the the client sending a message first???
I want to graph live data from my robot and new data will be available from a timer event on the ESP32 every 100ms so I assume then I have to have java script client side that sends a message every 100ms for the esp32 to respond with new data to???
edit
ok I seem to have worked it out by using setInterval(myFunction, 100); and am now successfully sending the needed data every 100ms.
Now to find some open source javascript for plotting the data :)
Post by OutoftheBOTS_ » Sun Feb 04, 2018 11:45 pm
Ok I am getting further but need a little advice.
So I think it works like this. The client needs to establish the websocket but once this is done the the client doesn't need to request a message the server can push out messages.
For the server to push out the message it needs a pointer to the websocket. The only way that I seem to be able to get a pointer to the websocket is have the client send a message first then make a global variable point to the websocket.
Once the client executes this javascript websocket = new WebSocket(wsUri); the webscoket is made, is there a way at the server side to detect this and get a pointer to it??
here is the round about way I made it work but it far from pretty coding
import utime
wsflag = False
  print("WS ACCEPT")
  webSocket.SendText("Reply for %s" % msg+ str(t))
  global wsflag
  global ws
  ws = webSocket
  wsflag = True
  print("WS CLOSED")
mws.Start()
t=0
while not wsflag : pass
  print(t)
  if  not ws.IsClosed() : ws.SendText(str(t))
  utime.sleep_ms(100)
  t+=1
