Hi all,
I’m new to PyBoard and MicroPython and have been experimenting with both for a few weeks - and may I say great work to all involved.
Now, however, I am working on sending and receiving data between a Raspberry Pi and several ESP32 dev boards over RS485. I have successfully used esptool to upload the MicroPython firmware for ESP32 over this network but am having some trouble with rshell. I’m trying to encorporate rshell in a short python script but get an error message. Rshell does work as expected when executed in lxterminal.
http://tomatopatch.ca/Share/code
http://tomatopatch.ca/Share/code_error_message
rshell, Raspberry Pi, ESP32, RS485
Re: rshell, Raspberry Pi, ESP32, RS485
One of the things that rshell does is to save/restore the state of stdin, and I'm guessing that the ioctl calls for doing that are inappropriate with certain devices (perhaps /dev/null).
I don't think that there is a current workaround without changing the code. I'll see if I can reproduce this and add some error handling that allows rshell to continue running even when the state of stdin can't be saved.
Thanks for taking an interest. Any help you can give on this will be greatly appreciated.
Found a dirty workaround.
I installed xterm and created a desktop shortcut containing the line:
my program contains the line:
So xterm opens a window and runs my python program which then opens an lxterminal window running rshell.
Works but yuck. Still open to suggestions.
Exec=xterm -e "python /home/pi/uPython/ESP32/RS485-Tools/DAPLC-ESP32-rShell.py"
subprocess.call("lxterminal -e /home/pi/uPython/ESP32/RS485-Tools/rshell-ESP32.sh", shell=True)
I've upgraded rshell to version 0.0.11 which should no longer get the exception you ran into.
You should be able to upgrade by doing:
sudo pip3 install --upgrade rshell
I've upgraded to rshell version 0.0.11 and no more exception messages.
Cheers
Cheers
