when I do this in REPL :
>>>import uasyncio
>>>loop = uasyncio.get_event_loop()
>>> loop. <--press Tab-->
__init__ remove_reader wait __qualname__
add_writer remove_writer add_reader __module__
It only shown above method? unlike usual upy modules, I've got all it class member.
uasyncio get_event_loop() methods
Re: uasyncio get_event_loop() methods
I think something is wrong with your installation. I see
Note that get_event_loop returns a PollEventLoop object, which is subclassed from EventLoop. It is an oddity of MicroPython that methods of the base class (such as create_task) aren't listed when Tab is pressed or dir() is targeted at a subclass instance.
MicroPython v1.9.2-69-gcc7fece on 2017-09-12; PYBv1.1 with STM32F405RG
>>> import uasyncio
>>> dir(loop)
['__init__', 'remove_reader', 'wait', '__qualname__', 'add_writer', 'remove_writer', 'add_reader', '__module__', 'q', 'poller', 'objmap']
>>> loop.
I think our REPL output is the same. here is my output :pythoncoder wrote: ↑Wed Oct 18, 2017 8:42 amI think something is wrong with your installation. I seeNote that get_event_loop returns a PollEventLoop object, which is subclassed from EventLoop. It is an oddity of MicroPython that methods of the base class (such as create_task) aren't listed when Tab is pressed or dir() is targeted at a subclass instance.Code: Select all
MicroPython v1.9.2-69-gcc7fece on 2017-09-12; PYBv1.1 with STM32F405RG Type "help()" for more information. >>> >>> import uasyncio >>> loop = uasyncio.get_event_loop() >>> dir(loop) ['__init__', 'remove_reader', 'wait', '__qualname__', 'add_writer', 'remove_writer', 'add_reader', '__module__', 'q', 'poller', 'objmap'] >>> loop. __init__ remove_reader wait __qualname__ add_writer remove_writer add_reader __module__ >>>
>>> import uasyncio
>>> loop=uasyncio.get_event_loop()
>>> dir(loop)
>>> loop.
viewtopic.php?f=16&p=22487#p22495
