rshell: unexpected EOF while parsing
ttmetro
Post by ttmetro » Sun Oct 22, 2017 10:29 pm
When starting rshell six-1.11.0 on ubuntu with
rshell -p /dev/ttyUSB0
I get the following error
Connecting to /dev/ttyUSB0 ...
  File "/usr/local/lib/python3.5/dist-packages/rshell/main.py", line 1185, in connect
    ip_address = socket.gethostbyname(port)
socket.gaierror: [Errno -2] Name or service not known
During handling of the above exception, another exception occurred:
  File "/usr/local/bin/rshell", line 11, in <module>
    load_entry_point('rshell==0.0.11', 'console_scripts', 'rshell')()
  File "/usr/local/lib/python3.5/dist-packages/rshell/command_line.py", line 4, in main
    rshell.main.main()
  File "/usr/local/lib/python3.5/dist-packages/rshell/main.py", line 2658, in main
    real_main()
  File "/usr/local/lib/python3.5/dist-packages/rshell/main.py", line 2620, in real_main
    connect(args.port, baud=args.baud, wait=args.wait, user=args.user, password=args.password)
  File "/usr/local/lib/python3.5/dist-packages/rshell/main.py", line 1191, in connect
    connect_serial(port, baud=baud, wait=wait)
  File "/usr/local/lib/python3.5/dist-packages/rshell/main.py", line 1215, in connect_serial
    dev = DeviceSerial(port, baud, wait)
  File "/usr/local/lib/python3.5/dist-packages/rshell/main.py", line 1436, in __init__
    Device.__init__(self, pyb)
  File "/usr/local/lib/python3.5/dist-packages/rshell/main.py", line 1273, in __init__
    self.name = self.remote_eval(board_name, self.default_board_name())
  File "/usr/local/lib/python3.5/dist-packages/rshell/main.py", line 1353, in remote_eval
    return eval(self.remote(func, *args, **kwargs))
  File "<string>", line 0
SyntaxError: unexpected EOF while parsing
Same error for
$ rshell
Welcome to rshell. Use Control-D to exit.
No MicroPython boards connected - use the connect command to add one
/home/ee49> connect telnet 192.168.10.104
Setup: ubuntu in VirtualBox running on top of OSX. I can connect to the (ESP32) from the pymakr atom plugin.
Bernhard Boser
Re: rshell: unexpected EOF while parsing
Post by pythoncoder » Mon Oct 23, 2017 12:19 pm
In a Ubuntu terminal run
ls /dev/tty*
Can you see /dev/ttyUSB0? If not, there may be some magic required to ensure the virtual machine manager exposes the OSX port to Ubuntu.
ttmetro
Post by ttmetro » Mon Oct 23, 2017 3:43 pm
Yes, it shows up in ubuntu when the device is plugged in, and disappears when unplugged.
Bernhard Boser
Post by pythoncoder » Wed Oct 25, 2017 6:34 am
Have you got a udev rule set up on the Ubuntu VM? See this post viewtopic.php?f=6&t=3843&p=22121&hilit=udev#p22121.
You also need to be a member of the dialout group - replace USER with your username
sudo usermod -a -G dialout USER
Failing the above, try running rshell as root - I'm not advocating this as a way of working but it might help diagnose permissions issues.
ttmetro
Post by ttmetro » Wed Oct 25, 2017 7:00 am
Thanks for your reply (and also libs, I use some, eg. MPU9250).
Doesn't seem a USB problem - I get the same error with 'connect telnet 192.168.10.104'. Also, pymakr (running on the ubuntu virtual machine) works.
I guess I'll need to download the rshell code and figure out what's wrong with the eval command. The SyntaxError is a bit odd. I'll report back once I get to it (for now I just use pymakr).
Bernhard
Bernhard Boser
Post by dhylands » Sun Oct 29, 2017 2:00 pm
What device is showing up as /dev/ttyUSB0 ? Under linux, the pyboard's show up as /dev/ttyACM0
Or perhaps you're using something other than a pyboad?
ttmetro
Post by ttmetro » Sun Oct 29, 2017 3:17 pm
Device is ESP32 with SiLabs USB (Adafruit Huzzah32).
In the meantime I found the issue occurs after installing Anaconda Python 3 distribution. [Totally idiotic coincidence - Anaconda has nothing to do with the problem, see next message.] So it appears to be one of these Python version and path mix up problems.
I suppose I need to install rshell in a local directory for debugging. Just have not gotten around to it yet.
Bernhard
Bernhard Boser
ttmetro
Post by ttmetro » Tue Oct 31, 2017 4:53 am
Mystery solved: I'd defined a module "board" on my esp32 but did not define a field "board.name". Apparently (and the documentation explains this) rshell expects this name if the module board exists.
If not,
self.remote(..., board_name, ('pyboard', ), {})
returns an empty string and the eval function called in remote_eval produces the error I was observing.
Possibly remote_eval could check the return value of self.remote before passing it to eval. But evidently I'm the only one ever running afoul of this error.
Many thanks to all who made suggestions!
Bernhard Boser
Post by dhylands » Tue Oct 31, 2017 7:33 pm
I filed an issue in rshell so I don't forget.
https://github.com/dhylands/rshell/issues/32
