Where can I find this documented? The micropython 1.9.3 doc for os.stat just states
The reason I care is that apparently the firmware I am using - loboris' python - uses 1970 as the base year and then rshell/rsync does not work properly. Presumably the firmware should be changed, following which documentation?uos.stat(path)
Get the status of a file or directory.
Bernhard
