Issues in Display data on LCD
nikhiledutech
Post by nikhiledutech » Sat Mar 31, 2018 9:23 am
I am unable to display data on LCD. Below is my code. Can anyone help me out.
import uasyncio as asyncio
import utime as time
from alcd import LCD, PINLIST
lcd = LCD(PINLIST, cols = 16)
async def lcd_task():
for secs in range(20, -1, -1):
lcd[0] = 'Edutech Learning'
lcd[1] = "Solution"
await asyncio.sleep(1)
loop.run_until_complete(lcd_task())
Can anyone help me out ?
cefn
Re: Issues in Display data on LCD
Post by cefn » Sun Apr 01, 2018 6:51 pm
You don't call runlcd
From https://github.com/peterhinch/micropyth ... 80/alcd.py
async def runlcd(self):                     # Periodically check for changed text and update LCD if so
Post by pythoncoder » Mon Apr 02, 2018 6:17 am
@cefn This is called by the constructor, there's no need to call it explicitly.
@nikhiledutech As far as I can see that code should run. Does the test program alcdtest.py run? If not I'd suspect a hardware problem.
nikhiledutech
Post by nikhiledutech » Mon Apr 02, 2018 8:52 am
it was running in past. But i tried it now and its not working. So definitely it should be a hardware problem ?
Post by pythoncoder » Mon Apr 02, 2018 1:28 pm
I've verified that lcdtest.py runs with firmware built today, with the current version of uasyncio, so I can only suggest checking hardware.
