isue when using new FTPlib module
katesfb
Post by katesfb » Tue Apr 10, 2018 5:38 am
I am trying out the port of FTPlib to micropython and i seem to have a bit of an issue. I am using a pyboard with a wifi skin and have successfully connected to the local WIFI. I then made use of the following example code from the ftplib.py file:
from ftplib import FTP
ftp = FTP('ftp.python.org')      # connect to host, default port
ftp.login()                               # default, i.e.: user anonymous, passwd anonymous@
ftp.retrlines('LIST')                # list directory contents
ftp.quit()
However i get the following error related to the 'ftp = FTP('ftp.python.org') ' line:
  File "main.py", line 100, in <module>
  File "ftplib.py", line 206, in __init__
  File "ftplib.py", line 264, in connect
  File "ftplib.py", line 226, in _create_connection
  File "ftplib.py", line 107, in _resolve_addr
TypeError: function takes 2 positional arguments but 3 were given
MicroPython v1.9.2 on 2017-08-23; PYBv1.1 with STM32F405RG
Any ideas what could have gone wrong here - i had a look at the _resolve_addr function but i dont know what i have done wrong.
Any help is much appreciated.
Cheers.
Re: isue when using new FTPlib module
Post by pythoncoder » Thu Apr 12, 2018 7:09 am
It would help if you told us more. A WiFi skin for the Pyboard? Sounds great, but I never knew such a thing existed. I assume you've tested this thoroughly before attempting FTP. A pointer to the board and any support code you're using would help.
Also please give a pointer to the ftplib you're using - there is no working code in micropython-lib.
katesfb
Post by katesfb » Sun Apr 22, 2018 11:19 pm
And thanks for the reply, much appreciated.
The link to the pyboard wifi skin is here https://www.tinyosshop.com/wifi-skin-fo ... er_name=py
This page also has some test code and library. Code seems to work in that i can connect the local wifi network with it. Thats all i have successfully done so far.
The ftplib i am using is here https://github.com/SpotlightKid/micropy ... /ftplib.py
My code and the associated error is below:
from pyb import Pin
import pywifi
print('Hardware reset for TONYLABS PyWifi')
print('=============================================')
rst = Pin('X12', Pin.OUT)
rst.low()
pyb.delay(20)
rst.high()
pyb.delay(500)
esp = pywifi.ESP8266(1, 115200)
print('Testing generic methods')
print('=======================')
print('AT startup...')
if esp.test():
    print('Success!')
    pyb.LED(1).on() #GREEN LED ON
    print('Failed!')
print('Soft-Reset...')
if esp.reset():
    print('Success!')
    print('Failed!')
print('Another AT startup...')
if esp.test():
    print('Success!')
    print('Failed!')
print('Check ESP8266 firmware version')
print('==============================')
esp.version()
print('Testing WIFI methods')
print('====================')
1: station mode
2: accesspoint mode
3: accesspoint and station mode
wifi_mode = 1
print("Testing get_mode/set_mode of value '%s'(%i)..." % (pywifi.WIFI_MODES[wifi_mode], wifi_mode))
esp.set_mode(wifi_mode)
if esp.get_mode() == wifi_mode:
    print('Success!')
    print('Failed!')
pyb.delay(100)
print('Connecting to network')
esp.connect(ssid='Taihoro', psk='Innxxxxxxx')
pyb.delay(20)
print(esp.get_station_ip())
pyb.LED(1).off() #GREEN LED ON
pyb.LED(4).on() #BLUE LED ON
print('Connecting to an FTP network')
ftp.quit()
Cheers.
katesfb
Post by katesfb » Mon Apr 30, 2018 3:04 am
Anybody have any ideas on this.
Cheers
Post by Roberthh » Mon Apr 30, 2018 5:59 am
What I see is an ordinary ESP8266 with AT firmware connected to a serial port of the PyBoard. What I do not see is any link into the Network stack of Micropython. Unless that is given, you cannot use the standard socket interface.
