MicroPython IDE
guyd
MicroPython IDE
Post by guyd » Tue Jul 24, 2018 1:13 pm
Since coding using VIM, rshell it to pyboard to debug it quite tiring, I'm looking for IDE for linux.
Guy
philwilkinson40
Re: MicroPython IDE
Post by philwilkinson40 » Tue Jul 24, 2018 10:50 pm
I think the lack of a strong IDE is a real barrier to entry to using Micropython (particularly for beginners).
As a hacker-level maker (non commercial) I personally use Atom on linux Ubuntu to write code and manage small projects. I can also directly interface with the REPL using Pycom's PYMAKR Atom plugin. If you are using Pycom boards the Pymakr functionality is far better of course.
I still use RSHELL to transfer files, so definitely not a complete IDE, but this set up suits my needs.
If you have the development skills, perhaps help MU-Editor develop their editor for more ports. Currently it supports Circuitpython and MicroBit.
guyd
Re: MicroPython IDE
Post by guyd » Wed Jul 25, 2018 3:34 am
Thank you for replying,
I'm using python for more than a year- so I'm not such a begginer :)
I've found
https://plugins.jetbrains.com/plugin/9777-micropython
, a pycharm plugin - which seems great- but I did find a real instuction installing and using it.
I have no problem using rshell to flash files, but more the fact of compile error, typos and so.
You mentioned atom - does it have a plugin for compiling ?
Re: MicroPython IDE
Post by pythoncoder » Wed Jul 25, 2018 5:03 am
...I have no problem using rshell to flash files...
You'll find that rshell is pretty capable - I recommend studying the readme and getting to know all its features. I use it exclusively. The one feature of an IDE I miss is a debugger but MicroPython currently lacks debugger support so, alas, you aren't going to find one. At least AFAIK.
guyd
Re: MicroPython IDE
Post by guyd » Wed Jul 25, 2018 8:35 am
well the lack of debugging is main issue- especially since some modules have different syntax, functions and so - which make debuggin only after flashing, tiresome.
Are you familiar with Pycharms MicroPython plugin ?
able_archer
Re: MicroPython IDE
Post by able_archer » Wed Jul 25, 2018 9:14 am
Hey, I'm in the same boat as you, was also looking for a full-featured but simple IDE under Linux for a while.
https://thonny.org/ has very recently released plugin support for Micropython and Circuitpython.
https://bitbucket.org/plas/thonny-micropython
Note that you shouldn't install the default release from the main page, but the newest (as of right now) thonny-2.2.0b4 beta from: https://bitbucket.org/plas/thonny/downloads/
And just follow the simple plugin installation instructions.
Thonny itself is meant for beginners, but seems to have all the important options, including debugging. You can also theme it as you see fit.
You still get the full REPL, but can also upload programs directly. And even flash new firmware from the looks of it. Pretty cool imo.
For installation instructions for Pycharms MicroPython plugin, see https://learn.adafruit.com/welcome-to-c ... cuitpython
There are also multiple Jupyter Notebook plugins, but I haven't looked into that yet.
And yes, it would be cool if they added support for mu-editor, its currently Circuitpython and Microbit only.
guyd
Re: MicroPython IDE
Post by guyd » Thu Jul 26, 2018 7:28 am
I tried PyCharm's plugin to Micropython.
For starters it an IDE, abit not easy to use/ install- but i'm working on it.
it offers flashing of project directly to pyboard.... Nice, but ... not perfect yet
able_archer
Re: MicroPython IDE
Post by able_archer » Thu Jul 26, 2018 7:57 am
Well, there are multiple options, not only Pycharm.
For an IDE that's less complex to install and configure, I recommend Thonny.
Just install the needed plugins and you're done.
guyd
Re: MicroPython IDE
Post by guyd » Sun Jul 29, 2018 9:03 am
must say that after installing Thonny- could able to use micropython plugin
BUT- after understanding PyCharm's plugin logic - it works 95% OK!!!
Guy
murilopolese
Re: MicroPython IDE
Post by murilopolese » Wed Oct 03, 2018 10:36 am
I use Mu Editor as my main MicroPython IDE. It's really great for small to medium projects.
It works with the BBC:micro-bit and Adafruit boards but also with a few ESP8266 and ESP32.
The only catch for the "non supported" boards is that you must run Mu Editor from the source code after poking a few lines.
The code is very readable. You just need to skip the "vid" and "pid" filter and you are ready to go: Capable code editor, REPL and file transfer.
I am also trying to grow https://flying-circus-ide.herokuapp.com/ into a fully capable MicroPython IDE but right now I'm mainly using it to work with devices over REPL, which Mu isn't able to.
Flying Circus works fine but I'm sure someone will do much better, so I also created https://github.com/murilopolese/webrepl-client which is all the Javascript you need to connect to the WebREPL, evaluate code, enter and exit raw repl, send keyboard interrupts, etc... I guess that could enable a plugin for Sublime/Atom/VSCode/Whatever web based editor.
