update NTP to timezone
guyd
Post by guyd » Tue Aug 14, 2018 5:02 am
I'm using micropython on ESP32, and during boot ( main.py ), and enabling wifi connection, I use the following code to update time
impoty ntptime
ntptime.settime()
How do I fix it to UTC+3 ?
Guy
Re: update NTP to timezone
Post by pythoncoder » Thu Aug 16, 2018 8:38 am
Timezone support is not yet implemented (as far as I know).
My approach is to let the RTC run UTC and perform the correction in code. Use mktime to get seconds since the epoch, add or subtract 3600*hours, and put the result into localtime. Rollover is then handled correctly.
guyd
Post by guyd » Thu Aug 16, 2018 12:40 pm
Hi
That was my first try... but since I need utc +3, adding 3*3600 to given time, I get hour 24, 25 when day changes ( and without date update)
Post by pythoncoder » Thu Aug 16, 2018 2:40 pm
I'm not sure I follow:
>>> import utime
>>> t =utime.mktime((2018,8,16,22,0,0,3,0))
>>> t += 4*3600
>>> utime.localtime(t)
(2018, 8, 17, 2, 0, 0, 4, 229)
The date and time have rolled over correctly. What I'm suggesting is code along these lines:
utime.localtime(utime.mktime(utime.localtime()) + 3*3600)
The innermost mktime() retrieves UTC time in seconds since the epoch. Add the offset and convert to a datetime tuple.
guyd
Post by guyd » Sat Aug 25, 2018 10:27 am
thank you.
I understand what you did different than me, but this why ( without updating "RTC" )- I'll need to convert time every time I need.
I wrote this :
import ntptime
import utime
ntptime.settime()
rtc = machine.RTC()
utc_shift = 3
tm = utime.localtime(utime.mktime(utime.localtime()) + utc_shift*3600)
tm = tm[0:3] + (0,) + tm[3:6] + (0,)
rtc.datetime(tm)
Realtime RTC updates
Post by pythoncoder » Sun Aug 26, 2018 5:38 am
Bear in mind that updating the RTC periodically can cause problems depending on the design of your application.
This is because sudden jumps in the RTC time can cause issues if any part of the application uses the RTC for timing. This can be avoided by letting the RTC free-run and performing corrections at runtime.
guyd
Post by guyd » Sun Aug 26, 2018 7:41 am
thank you for pointing it out ( earlier ) - Since ESP has scheduled tasks, I altered the design that a main RPI send MQTT commands ( on schedule ) to activate ESP clients.
Guy
