micropython-lib project: CPython backports
pfalcon
Post by pfalcon » Sat Oct 13, 2018 11:15 am
Recently, with the increasing number of packages which work both on MicroPython and CPython, I figured it might be a good idea to provide "MicroPython compatibility layer" for CPython. Put simply, you could "import utime" on CPython and use MicroPython's extended functions available in this module (and vice-versa, wouldn't be able to use functions not available in MicroPython).
The usecases enabled by this are:
  • "MicroPython first" module development. I.e. modules can be developed and optimized for MicroPython, the efficient Python language implementation, while still work on bloated implementations like CPython.
  • Reuse of the wealth of tools available for CPython, like debuggers, syntax/style checkers, coverage, etc.
  • Porting large MicroPython libs/apps to CPython. For example, uasyncio used to work on CPython by monkey-patching CPython's asyncio, but as it evolved, it became impractical/inefficient to do that. Implementing uasyncio dependencies, like utime, uselect, etc. is a better way.
  • Overall proof that despite differences in standard libraries, MicroPython and CPython are members of one big Python ecosystem.
For more information, see https://github.com/pfalcon/micropython- ... -backports
An example:
$ pip3 install --user micropython-cpython-uhashlib
$ python3
>>> import uhashlib
>>> uhashlib.sha1(b"test").hexdigest()
AttributeError: 'sha1' object has no attribute 'hexdigest'
# MicroPython's uhashlib doesn't have hexdigest(), use ubinascii.hexlify(.digest())
>>> uhashlib.sha1(b"test").digest()
b'\xa9J\x8f\xe5\xcc\xb1\x9b\xa6\x1cL\x08s\xd3\x91\xe9\x87\x98/\xbb\xd3'
To remind, the master micropython-lib repository is https://github.com/pfalcon/micropython-lib . Issues reports and patches adhering to Contributor Guidelines are welcome.
Awesome MicroPython list
mattyt
Re: micropython-lib project: CPython backports
Post by mattyt » Sat Oct 13, 2018 11:32 pm
This is a very helpful contribution, thanks! I see it as being especially useful for unit testing where it can be much easier to run tests (at least first) on a PC.
Note that there's a similar effort in the CircuitPython space - adafruit_blinka. It's a little different since, as this guide explains, the main purpose is to allow CircuitPython code to run on Raspberry Pi, BeagleBone Blacks and generally Linux - but with support for GPIO, SPI and I2C. Maybe there's something in there that you might find useful?
In any case, thanks again @pfalcon!
pfalcon
Post by pfalcon » Fri Oct 19, 2018 6:17 am
Right. But actually, it's possible for quite some to do unit testing using MicroPython itself (with Unix port if doing on a PC). The corresponding module (unittest) is in micropython-lib: https://github.com/pfalcon/micropython- ... r/unittest . It surely doesn't have all the features CPython's counterpart has, but a few people contributed to it, which is a sign they actually find it useful.
For more complex tools, like code coverage or debuggers, running the code using CPython may be the most "low-hanging" way indeed.
Sure, it's great to see more MicroPython related projects around!
pfalcon
Post by pfalcon » Sun Dec 16, 2018 9:18 pm
There's noticeable progress with CPython module backports - now it's possible to run the "upip" package manager on CPython using them:
$ pip3 install --user micropython-cpython-upip
Collecting micropython-cpython-upip
  Downloading https://files.pythonhosted.org/packages/23/86/7a98c5b0840d65ffbe6e71a0a9bd2ab93f5c938542b84a3c4824d2fc1553/micropython-cpython-upip-1.2.6.tar.gz
Collecting micropython-cpython-uerrno (from micropython-cpython-upip)
  Using cached https://files.pythonhosted.org/packages/55/65/06f724152cc383704b44a92a2d4dc8f62159f64c6bbb84e21f83b62aeb28/micropython-cpython-uerrno-0.1.tar.gz
Collecting micropython-cpython-ujson (from micropython-cpython-upip)
Successfully installed micropython-cpython-micropython-0.2 micropython-cpython-uerrno-0.1 micropython-cpython-uio-0.2 micropython-cpython-ujson-0.1 micropython-cpython-uos-0.1 micropython-cpython-upip-1.2.6 micropython-cpython-usocket-0.1 micropython-cpython-ussl-0.1 micropython-cpython-uzlib-0.1
$ python3 -m upip install -p install_dir notes-pico
Installing to: install_dir/
Warning: pypi.org SSL certificate is not validated
Installing notes-pico 0.8.9 from https://files.pythonhosted.org/packages/93/d3/f15081396c45b77709c9346215a45836130ae0367e801d17bb69a19751a3/notes-pico-0.8.9.tar.gz
Installing picoweb 1.5.1 from https://files.pythonhosted.org/packages/56/5c/4540e02d8be5b4dc3cc705a3047fb54c1d79e98f49b115290d7a2e736f5d/picoweb-1.5.1.tar.gz
Installing utemplate 1.2 from https://files.pythonhosted.org/packages/ce/c3/6ef0cc5c256c2192d8f6ff0175a6b6c3dff727fdb6ec1eb432fc0a2a97e9/utemplate-1.2.tar.gz
Installing micropython-logging 0.4.1 from https://files.pythonhosted.org/packages/46/93/7ce7c6632c59a47908b068d047d7b76c4505c6bf2b2dfa53b540fb1881bc/micropython-logging-0.4.1.tar.gz
Installing micropython-pkg_resources 0.2.1 from https://files.pythonhosted.org/packages/58/87/5acc262e0f642186891ef8d944bd727989000ce8d9263514f73b8feb7fdc/micropython-pkg_resources-0.2.1.tar.gz
Installing micropython-btreedb 0.3 from https://files.pythonhosted.org/packages/c4/03/b60fdda40235da6322ce11948a2576da7a2d8c4fe56d31f4440388e49a59/micropython-btreedb-0.3.tar.gz
Installing micropython-uasyncio 2.1.1 from https://files.pythonhosted.org/packages/0c/33/cbd1ee245621dab9952ebd1d3be840e6acd66e847b33ea88a7f015d2b952/micropython-uasyncio-2.1.1.tar.gz
Installing micropython-os 0.7.1 from https://files.pythonhosted.org/packages/a7/dc/9956b7ea7e4cc46e3d2a326225a2ea48fe66bcbea03f7ac0c84519445c4d/micropython-os-0.7.1.tar.gz
Installing micropython-uasyncio.core 2.0.1 from https://files.pythonhosted.org/packages/39/9f/619bbe7454419b72073e61b3d9abbc5dfeb54cc4062c2a2d21ad4984db85/micropython-uasyncio.core-2.0.1.tar.gz
Installing micropython-ffilib 0.1.3 from https://files.pythonhosted.org/packages/81/8a/5c3e6188384fbb57800a188d24582dc1a16b4fc8b538e0ba58aa443e3573/micropython-ffilib-0.1.3.tar.gz
Installing micropython-errno 0.1.5.1 from https://files.pythonhosted.org/packages/c5/bc/ac0b6e27a37f985ac5237ad1a6633a89a646cb23152c27fecca368abe811/micropython-errno-0.1.5.1.tar.gz
Installing micropython-stat 0.5.1 from https://files.pythonhosted.org/packages/cf/cf/fde35e109408fb94a5c00725e53608dada21a6b3eaa04dfd4189a8def2c1/micropython-stat-0.5.1.tar.gz
$ MICROPYPATH=install_dir micropython -m notes_pico.__main__
* Running on http://127.0.0.1:8081/
pfalcon
Post by pfalcon » Fri Feb 22, 2019 5:36 am
Initial backports of "ffi" and "uctypes" modules are available. Functionality is enough to e.g. run ffi_example.py from MicroPython distro:
$ pip3 install --user micropython-cpython-ffi
$ pip3 install --user micropython-cpython-uctypes
$ cd micropython/examples/unix
$ python3 ffi_example.py
libc: <ffi.DynMod object at 0x7f8d8992f0f0>
time: <ffi.Func object at 0x7f8d8992f978>
UNIX time is: 1550813462
perror before error: Success
errno object: <ffi.Var object at 0x7f8d8991d278>
errno value: 0
perror after error: Success
callback: <CFunctionType object at 0x7f8d8b22db38>
org string: bytearray(b'foobar')
cmp: b'o' b'o'
cmp: b'f' b'o'
cmp: b'a' b'r'
cmp: b'b' b'a'
cmp: b'b' b'r'
cmp: b'f' b'a'
cmp: b'f' b'b'
cmp: b'f' b'r'
cmp: b'o' b'r'
cmp: b'o' b'r'
qsort'ed string: bytearray(b'abfoor')
pfalcon
Post by pfalcon » Fri May 10, 2019 10:11 pm
The project gradually progress. The latest module released is https://pypi.org/project/micropython-cpython-ure/ (very bare, yeah).
