I have looked around the forum but there no question on ESP32 DEVKIT uart. I want to have a simple application that will send AT command to another board from ESP32 DEVKIT and read whatever the other board response.
I flashed esp32-20190125-v1.10.bin firmware. There are no uasyncio and I am unsure what library UART from machine has. Do we have a way to check it ?
I wrote an independent program to test UART
uart = UART(2, baudrate=9600 )
uart.init(bits=8, parity=None, stop=1)
time.sleep(2)
uart.write('print(1+2)\r\n')
uart.read()
I (401) cpu_start: Pro cpu up.
I (401) cpu_start: Single core mode
I (401) heap_init: Initializing. RAM available for dynamic allocation:
I (404) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (410) heap_init: At 3FFC0E38 len 0001F1C8 (124 KiB): DRAM
I (417) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (423) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (429) heap_init: At 400915EC len 0000EA14 (58 KiB): IRAM
I (436) cpu_start: Pro cpu start user code
I (6) cpu_start: Starting scheduler on PRO CPU.
I (90) uart: ALREADY NULL
