HX711 - which lib should I use?
Re: HX711 - which lib should I use?
we are using 1kg strain gauge load cell.
Thankyou so much for your help, it's all done.
without you may be we can't do it. thanks a lot
hello again,
I'm new to the python and need some help from you.
actually, we are using 3 stepper motors for 1 pico and for each stepper motor I have independent codes, only difference is the pin number that is (for stepper motor 1 the pin is 2, for stepper motor 2 the pin is 6, for stepper motor 3 the pin is 10)
I want only single code with all these pin numbers and should run all together.
can anyone help me with that.. I am attaching the code below.
from rp2 import PIO, StateMachine, asm_pio
from time import sleep
import sys
@asm_pio(set_init=(PIO.OUT_LOW,) * 4,
out_init=(PIO.OUT_HIGH,) * 4,
out_shiftdir=PIO.SHIFT_LEFT)
def prog():
pull()
mov(y, osr) # step pattern
pull()
mov(x, osr) # num steps
jmp(not_x, "end")
label("loop")
jmp(not_osre, "step") # loop pattern if exhausted
mov(osr, y)
label("step")
out(pins, 4) [31]
nop() [31]
nop() [31]
nop() [31]
jmp(x_dec,"loop")
label("end")
set(pins, 8) [31] # 8
sm = StateMachine(0, prog, freq=10000, set_base=Pin(2), out_base=Pin(2))
sm.active(1)
sm.put(2216789025) #1000 0100 0010 0001 1000010000100001
sm.put(1000)
sleep(100)
sm.active(0)
sm.exec("set(pins,0)")
@kiranmai1268
Welcome to micropython,
Your issue is note related to HX711, and it is specific to pico, you should post pico section of the forum
nodemcu V2 (amica)
micropython firmware Daily build 05/31/2016
