HX711 - which lib should I use?
Re: HX711 - which lib should I use?
Which variant of (Micro-)Python do you use? And which HX711 lib?
I'm a little bit puzzled by the constructor
hx711 = HX711(5,6)
Because HX711 expects pin objects top be supplied. But maybe you use a different lib.
hx711 = HX711(5,6)
we are trying to run code using RPi 4b
and i'm running in things in thonny.
Which HX711 lib do you use?
So nothing to do for me.
Hi there,
we are working on 1kg load cells and HX711 amplifier. I have tried multiple source codes to run on raspberry pi Pico. however unfortunately, the code is working but the thing is printing only zero's as the output.
I tried to change the code but it doesn't work.
I'm attaching the link of the video with our connections and code
https://1drv.ms/v/s!Ah1A9_q5Vo-jhUxWyfL ... B?e=Ue6dmO
here, the code which we used.
https://github.com/robert-hh/hx711
it would be so great if you could help with that.
Thank You.
Thank You.
The video is almost useless. It is better if you write down, which connection you made. The pins have names & numers. And you can as well paste your code here. No need to show a video. At least, it seems that you connected the HX711 to GPIO 2 and 3 (Pin(2) and Pin(3)). So these numbers should be in our script.
The pins we used are pin 12 and pin 13
I'm attaching the image of the connections we made.
https://1drv.ms/u/s!Ah1A9_q5Vo-jhU0JsnG ... B?e=ZPWmKL
and here is the code we used.
from hx711_gpio import HX711
pin_OUT = Pin(12, Pin.IN, pull=Pin.PULL_DOWN)
pin_SCK = Pin(13, Pin.OUT)
hx711 = HX711(pin_SCK, pin_OUT)
hx711.tare()
value = hx711.read()
value = hx711.get_value()
THESE ARE THE CODES....
from machine import enable_irq, disable_irq, idle
class HX711:
def __init__(self, pd_sck, dout, gain=128):
self.pSCK = pd_sck
self.pOUT = dout
self.pSCK.value(False)
self.GAIN = 0
self.OFFSET = 0
self.SCALE = 1
self.time_constant = 0.25
self.filtered = 0
self.set_gain(gain);
def set_gain(self, gain):
if gain is 128:
self.GAIN = 1
elif gain is 64:
self.GAIN = 3
elif gain is 32:
self.GAIN = 2
self.read()
self.filtered = self.read()
def is_ready(self):
return self.pOUT() == 0
def read(self):
# wait for the device being ready
for _ in range(500):
if self.pOUT() == 0:
break
time.sleep_ms(1)
raise OSError("Sensor does not respond")
# shift in data, and gain & channel info
result = 0
for j in range(24 + self.GAIN):
state = disable_irq()
self.pSCK(True)
self.pSCK(False)
enable_irq(state)
result = (result << 1) | self.pOUT()
# shift back the extra bits
result >>= self.GAIN
# check sign
if result > 0x7fffff:
result -= 0x1000000
return result
def read_average(self, times=3):
sum = 0
for i in range(times):
sum += self.read()
return sum / times
def read_lowpass(self):
self.filtered += self.time_constant * (self.read() - self.filtered)
return self.filtered
def get_value(self):
return self.read_lowpass() - self.OFFSET
def get_units(self):
return self.get_value() / self.SCALE
def tare(self, times=15):
self.set_offset(self.read_average(times))
def set_scale(self, scale):
self.SCALE = scale
def set_offset(self, offset):
self.OFFSET = offset
def set_time_constant(self, time_constant = None):
if time_constant is None:
return self.time_constant
elif 0 < time_constant < 1.0:
self.time_constant = time_constant
def power_down(self):
self.pSCK.value(True)
def power_up(self):
According to the picture, you connect to SCK to GPIO19 and DOUT to GPIO18. So the setting must be:
pin_OUT = Pin(18, Pin.IN, pull=Pin.PULL_DOWN)
pin_SCK = Pin(19, Pin.OUT)
why this error occuring?/
earlier the pico, everything is working fine but suddenly it is showing the option for saving the files in pico as well.
https://1drv.ms/u/s!Ah1A9_q5Vo-jhU7gQP0 ... O?e=Uvgsui
