machine.idle() just serves the purpose of avoiding a busy loop. time.sleep_ms(1) works as well.
Edit: I see machine.idle(). May you should use the daily build firmware. It progresses fast at the moment.
HX711 - which lib should I use?
Re: HX711 - which lib should I use?
Thanks the latest update appears to have fixed that issue, I have it working now for the scales.py file, with GPIO 16 as the data pin and GPIO as the clock pin. when I tried to run your hxtest.py example I am getting the following terminal message:
This is the only change I have made so far:Traceback (most recent call last):
File "<stdin>", line 5, in <module>
File "/lib/hx711_spi.py", line 9, in __init__
TypeError: extra keyword arguments given
from hx711_spi import *
hx = HX711(16, 18, 19)
The driver uses the SPI call logic of pycom. You have to change that line in hx711_spi.py to:
self.spi = SPI(0, mode=SPI.MASTER, baudrate=1000000, polarity=0,
phase=0, sck=Pin(spi_clk), mosi=Pin(pd_sck), miso=Pin(dout))
Please note that the SPI clock will NOT be connected. The HX711 will be clocked by the mosi pin.
Thank you Robert. I think I have it working now. I am using GPIO 16 as the data (miso) pin and GPIO 19 as the skc (mosi) pin.
Now to turn it into meaningful results! The plan is to make a data logger which I can use with load cells for work.
I'm working with a high school robotics team that want's to use the hx711 with a pico to design some "smart" exercise equipment.
Would you be willing to share some samples of your code?
Jeff
Jeff
The repository contains samples of the code. At the moment, the SPI version is the best to use. But I can also make a PIO version, which makes use of the PIO state machine and should perform better. Just give me a day or two for set-up.
There is a variant now of the driver using the RP2040's PIO at https://github.com/robert-hh/hx711
Like the GPIO version it uses two pins only, but unlike GPIO, once started the timing cannot be affected by interrupts.
