Fast RGB to HSV (And vice versa) calculations?
hdsjulian
Post by hdsjulian » Sun Mar 17, 2019 12:55 pm
I'm looking for a way to calculate hsv and rgb values respectively. So far I just have used straight forward python implementation that does it, but it is _very_ slow (1.7ms on an esp8266).
    h = float(h)
    s = float(s)
    v = float(v)
    h60 = h / 60.0
    h60f = math.floor(h60)
    hi = int(h60f) % 6
    f = h60 - h60f
    p = v * (1 - s)
    q = v * (1 - f * s)
    t = v * (1 - (1 - f) * s)
    r, g, b = 0, 0, 0
    if hi == 0: r, g, b = v, t, p
    elif hi == 1: r, g, b = q, v, p
    elif hi == 2: r, g, b = p, v, t
    elif hi == 3: r, g, b = p, q, v
    elif hi == 4: r, g, b = t, p, v
    elif hi == 5: r, g, b = v, p, q
    r, g, b = int(r * 255), int(g * 255), int(b * 255)
    return r, g, b
Anyone here who has had similar problems and found a solution?
mattyt
Re: Fast RGB to HSV (And vice versa) calculations?
Post by mattyt » Tue Mar 19, 2019 1:46 am
I suggest first taking a look at Maximising MicroPython Speed to determine if you can apply any of the techniques there to improve the performance in MicroPython. Damien's PyCon AU talk on Writing fast and efficient MicroPython is full of useful tips too. Some of those may help get performance to an acceptable level for your implementation.
That said, numerical conversions - particularly if they need to be repeated frequently - are often good candidates to write as a C module. The Loboris port has completed half the work; an rgb_to_hsb conversion function in C and the NeoPixel module that allows it to be accessed from MicroPython. It's just that the implementation is bound to the NeoPixel module - you'd need to extract those parts and create a separate module. You might find that Mike Teachman's argument_examples may be useful to help define the interface to MicroPython from C.
Even better, it would be fantastic if you were to implement this as the start of a standard implementation of the colorsys module which MicroPython currently lacks. I for one would really appreciate it! :)
hdsjulian
Post by hdsjulian » Tue Mar 19, 2019 6:19 pm
unfortunately the whole reason i started using micropython on my esp8266 was that i just don't do well with C and i'd rather focus on getting my actual projects done (otherwise i could also just use arduino) :) so i doubt any c-stuff will come from me :/
mattyt
Post by mattyt » Wed Mar 20, 2019 12:55 am
Completely understand; so perhaps start with trying to apply the MicroPython performance suggestions.
I'd like to tackle implementing it as C module but spare time is currently in desperately short supply! I'll bump it up the priority list and try to get to it... In the meantime, please keep us posted as to how you progress using MicroPython!
jickster
Post by jickster » Wed Mar 20, 2019 1:43 am
Seems a perfect application for viper.
https://www.kickstarter.com/projects/21 ... ontrollers
mattyt
Post by mattyt » Wed Mar 20, 2019 1:47 am
Viper is great - unless you want it to work on multiple ports. Most of my development is on the ESP32 right now where there is no Viper implementation...
jickster
Post by jickster » Wed Mar 20, 2019 1:48 am
mattyt wrote:Viper is great - unless you want it to work on multiple ports. Most of my development is on the ESP32 right now where there is no Viper implementation...
What about “@native”?
mattyt
Post by mattyt » Wed Mar 20, 2019 4:05 am
According to the forum post native and viper decorators on the ESP32 neither decorators are available for the ESP32.
It's possible that it has been added to the ESP32 port since that post but I couldn't find anything obvious in the codebase that made it clear...
oclyke
Post by oclyke » Wed Mar 20, 2019 4:46 pm
When I see HSV->RGB I think of this great write-up and portable C library: http://www.vagrearg.org/content/hsvrgb
Of course, not too helpful in the near-term but since mattyt is talking about a colorsys module it might be helpful. Speaking of which, I'd like to help out with something like that. Let's coordinate!
And even if you don't want to write C the article at that link is still a good read if you like math and optimizations :D
marfis
Post by marfis » Wed Mar 20, 2019 7:23 pm
according to this
https://github.com/micropython/micropython/issues/4607
it doesn‘t have priority for Damien.
