[Solved] Noob has questions about exec() and import()
sebi
Post by sebi » Tue Mar 26, 2019 11:32 pm
Dear all,
My problem has to do with exec, import and globals
For ease of illustration, I create a file named code.py, the content of which being:
class A:
    pass
a=A()
a.b=1
def toggle():
    a.b*=-1
toggle()
When I type the following commands under MicroPython's prompt I get:
MicroPython v1.10-131-g952139904 on 2019-02-26; PYBv1.1 with STM32F405RG
>>> def do(): exec(open("code.py").read())
>>> do()
>>> dir()
['__name__', 'toggle', 'a', 'do', 'A']
>>> a.b
-1
...which is what I expect, and provides the same results as when typing all the lines of code.py directly under MicroPython's prompt.
However, if I create a file named make.py, the content of which being:
def do():
def do2():
    exec(open("code.py").read(), globals())
and I type the following commands under MicroPython's prompt, I get:
>>> from make import do
>>> do()
  File "make.py", line 1, in do
  File "<string>", line 10, in <module>
  File "<string>", line 8, in toggle
NameError: name 'a' isn't defined
>>> dir()
Q: Why do I get this error even thought a is obviously in the global namespace?
If I restart MicroPython and type:
>>> from make import do2
>>> do2()
>>> dir()
['__name__', 'do2']
>>> a.b
...which is not what I am looking for, as I would like a.b=-1.
Q: Could someone help me understand the underlying mechanisms of exec and import?
PS: I have noticed that def func(): exec('a=2') under MicroPython does the same job as def func(): exec('a=2', globals()) under CPython 3: executing func() will create a variable a, the value of which is 2, in the global namespace.
Q: Why globals() can be omitted under MicroPython for such an example?
Re: Noob has questions about exec() and import()
Post by OutoftheBOTS_ » Tue Mar 26, 2019 11:49 pm
Hopefully I can help and give correct answers and if I am incorrect someone will correct me :)
First it is a little bit of a round about way you loading into RAM your code from code.py the following will do the same thing
import code
also I think your getting namespace incorrect
>>> do2()
>>> dir()
['__name__', 'do2']
>>> a.b
maybe try this name space because of the way you have imported it
do2.a.b
sebi
Post by sebi » Wed Mar 27, 2019 2:07 am
Thanks for your reply OutoftheBOTS_
__class__       __name__        do2
>>> do2.__
__class__       __name__
>>> do2.a.b
AttributeError: 'function' object has no attribute 'a'
>>> import code
>>> code.a.b
-1
>>> code.toggle()
>>> code.a.b
1
>>> from code import *
>>> a.b
-1
>>> toggle()
>>> a.b
1
do2.a.b doesn't do the job.
import does exactly what I want, but only once...
If I modifiy code.py with, let's say, a.b=11, save the file, and type:
>>> from code import *
>>> a.b
1
>>> import code
>>> code.a.b
1
>>> from make import reload
>>> reload(code)
<module 'code' from 'code.py'>
>>> code.a.b
1
>>> from make import run
>>> run("code")
  File "make.py", line 13, in run
>>> a.b
-11
...import doesn't take into accounts the changes I have made to code.py.
Neither reload.
and run yields the error I have described in my original post.
I added the following code to make.py:
def reload(mod):
    import sys
    mod_name = mod.__name__
    del sys.modules[mod_name]
    return __import__(mod_name)
def run(file):
    """ Run given file (without extension) """
    exec(open(file + ".py").read())
where reload is taken from one of your posts.
Only exec(open("code.py").read()) does the job correctly!
My goal would be to have run("code") doing the very same as exec(open("code.py").read()).
Do you know how to do that?
Post by OutoftheBOTS_ » Wed Mar 27, 2019 9:30 pm
I add the the reload function to my boot.py so that it sets up during boot up
here is my boot.py
# This file is executed on every boot (including wake-boot from deepsleep)
import sys, gc
sys.path[1] = '/flash/lib'
def reload(mod):
  gc.collect()
This has the effect of removing the module from RAM then reloading it.
Now
I am in process of moving house so can't run anythiong on a MP board to test atm but try this.
create your code.py
class A:
    pass
a=A()
a.b=1
def toggle():
    a.b*=-1
toggle()
load the code.py into ram
import code
try your tests
dir()
a.b
toggle()
a.b
sebi
Post by sebi » Wed Mar 27, 2019 10:39 pm
Dear OutoftheBOTS_,
Thanks for your assistance.
I followed your instructions:
- modified boot.py with your code
- rebooted the MicroPython device
- loaded the content of code.py into RAM using import
- printed the value of code.a.b
- modified the value of a.b in code.py
- exectued reload(code)
--> I still got its original value (the one before modification).
I don't understand it but it seems reload doesn't do its job properly.
Can you confirm once you have some more free time?
Details below:
MicroPython v1.10-8-g8b7039d7d on 2019-01-26; ESP module with ESP8266
>>> import code
>>> code.a.b
-1
Uploading project (main folder)...
Not safe booting, disabled in settings
Reading file status
[1/1] Writing file code.py (0kb)
Upload done
>>> reload(code)
<module 'code'>
>>> code.a.b
-1
Post by dhylands » Wed Mar 27, 2019 11:05 pm
The problem is that there is a local variable called code which is holding onto the old copy of code.
When you reload(code) this can't change the local variable.
After you call reload(code) you can then do:
del code
import code
and you'll now have a reference to the new code.
The proper way use reload is to to this:
code = reload(code)
this will replace the local variable code with the newly imported version of code.
sebi
Post by sebi » Thu Mar 28, 2019 3:36 am
Dear Dave,
Thanks a lot for your explanations!
It really gave me a lot to think of, especially that notion of local variable holding the code.
I searched for a way to get reload(mod) modify that variable directly, and eventually I modified its last line such a way:
def reload(mod):
    import sys
    exec("import {}".format(mod_name))
...and it seems to work.
Typing reload(code) only does the job:
When updating code.py, modifications are reflected.
I will still investigate exec() which is still mysterious to me, but I thank you a lot for your help!
Post by dhylands » Thu Mar 28, 2019 4:09 am
Fundamentally, doing the exec won't work for all situations.
You really need to do code = reload(code). That's the only way to cover all of the edge cases. The exec case only works if the original code variable is a global. If it isn't a global, then it won't do what you want it to.
sebi
Post by sebi » Sun Mar 31, 2019 8:45 pm
Indeed the only good way is code = reload(code).
Is there a similar way to reload a module after a from code import *?
Actually, currently I prefer to use exec(open("code.py").read()) instead as I don't understand the program behavior after a from code import *.
Indeed, for code.py being:
a = 0
def func():
    global a
    a = 1
if I type from code import *; func(); print(a) I get 0 instead of 1 as I would have expected. Why?
Post by OutoftheBOTS_ » Sun Mar 31, 2019 9:28 pm
First of all how about you tell us what your trying to achieve?
If it is simply writing code into a py file (i.e myscript_file.py) then loading it into RAM instead of having to type the script into the REPL then you can simply just use
import myscript_file
This works perfectly for me :)
