Does anyone know a library for the grove board with gas multi sensor with MICS-6814 (I2C)
http://wiki.seeedstudio.com/Grove-Multi ... as_Sensor/
thanks in advance
Carvals
MICS-6814 I2C grove
Re: MICS-6814 I2C grove
I didn‘t search for a library but I skimmed through the code of the Arduino Lib. Looks like easy I2C communication which you can easily port to Micropython if needed. Sp even without a library this is a simple task!
Thanks. Yes I will do that. I asked in case it was done I could contribute
ok I am lazy too lol
I found this one https://github.com/DexterInd/GrovePi/bl ... _sensor.py
but I would not call that a library....
thanks
thanks
