os.walk('.') in micropython
nodepythoner
Post by nodepythoner » Sun Apr 21, 2019 7:28 pm
how to realize os.walk() command in micropython
i need to take all content in flash(files in other directories)
but os has not that command :(
Re: os.walk('.') in micropython
Post by dhylands » Mon Apr 22, 2019 12:02 am
You can use os.listdir() to get a list of all files in a directory and os.stat to determine which of those are directories and recurse.
This is what rshell does for its rsync command.
You could also take the os.walk implementation from here: https://github.com/micropython/micropyt ... __.py#L147
nodepythoner
Post by nodepythoner » Mon Apr 22, 2019 6:22 am
THANKS! :)
i wrote changed code:
import uos
files=[]
dirs=[]
def S_ISDIR(fname):
        f = open(fname, "r")
        exists = True
        f.close()
    except OSError:
        exists = False
    return(exists)
def walk(top):
    for dirent in uos.ilistdir(top):
        #print(dirent)
        mode = dirent[1] << 12
        fname = dirent[0]
        if S_ISDIR(fname):
            dirs.append(fname)
            files.append(fname)
    yield top, dirs, files
    for d in dirs:
        yield from walk(top + "/" + d)
for top, dirs, files in walk('/sd'):
    print(dirs,files)
i changed isdir function(tryes open a file. you cant open a dir)
