How to send file using urequests.
r2xxd2
Post by r2xxd2 » Sun May 19, 2019 6:32 am
I need help. I'm trying to send a jpg file as Telegram bot.
In Python we can use construction like this:
import requests
url = 'https://api.telegram.org/botXXXXXX/sendPhoto'
f = {'photo': open("sd/photo.jpg", "rb")}
data = {'chat_id' : 'XXXXXXX'}
requests.post(url, data=data, files=f)
How can we upload file using "urequests"
Re: How to send file using urequests.
Post by jimmo » Sun May 19, 2019 10:26 am
The urequests module doesn't include all of the features of the one from big Python.
But you can do it manually by crafting your own POST request using the multipart/form-data Content-Type.
See https://developer.mozilla.org/en-US/doc ... ST#Example for an example
And depending on how far you feel like following the code path through the Python requests library, you can see their implementation. Here's a starting point https://github.com/kennethreitz/request ... /models.py (see `def _encode_files`).
r2xxd2
Post by r2xxd2 » Thu May 23, 2019 4:45 am
Thank you!
r2xxd2
Post by r2xxd2 » Fri May 24, 2019 3:55 am
Sorry, but I still need help... could anyone please share the real example or project how to use multipart/form-data Content-Type and what additional modules or functions I need to create for sending file through POST request.
Thanks.
Post by jimmo » Fri May 24, 2019 6:07 am
Can you share what you've got so far. But here are some hints...
So you're going to need to set up a headers dict to pass to `requests.post` (which sets the content-encoding) and then it's a matter of generating a string to pass as the `data` parameter which is the encoded parameters (chat_id and files).
Adapting the example from the page I linked to
headers = {'Content-Type': 'multipart/form-data;boundary="boundary"'}
Here's
--boundary
Content-Disposition: form-data; name="chat_id"
XXXXXXX
--boundary
Content-Disposition: form-data; name="photo"; filename="foo.jpg"
<contents of foo.jpg>
--boundary--
You can build this up by appending to a bytearray or something.
You'll want to use something a bit more unique for the boundary (generate some random string maybe). Perhaps read the spec linked from that page (https://tools.ietf.org/html/rfc2046#section-5.1.1)
zvafqthr
Post by zvafqthr » Thu Nov 21, 2019 8:20 pm
Hey. I also had the need to send files through the telegram bot, I read the topic and did not understand how this can be implemented on a micropython. Can you write example of request?
Huntaway55
Post by Huntaway55 » Sun Apr 05, 2020 9:55 pm
I came across this thread when was looking to upload files in micropython. Following the requests library source, I was able to hack something together to get file uploading to work in micropython urequests.
I've pushed the code to Github.
https://github.com/jono-allen/MQTT-Cam/ ... ploader.py
I'll also push the app that controls the board in the next week when I finish the AWS cloudformation side.
