Software and call Class
giants
Post by giants » Sun May 19, 2019 4:34 pm
Hello everyone!
i'm here again for ask your help.
1) I use uPyCraft V1.1 for program my ESP8266 it's a good program or there are any other work much better ?
2) I wrote my first class ,but when i try to download gave me one error InportError: no module named 'RFD77402' is because didn't find where my class is ? i need the use path ? if yes can you help me please
Thank you so much
Sergio
Re: Software and call Class
Post by jimmo » Thu May 23, 2019 12:26 am
It seems fine! This is more of a personal choice. It looks like it makes it easy to get files on/off the ESP8266 so that's good... (this is the usual thing that people have trouble with because there's only a serial interface, no easy USB filesystem like on the pyboards).
Sounds like it. If you have a line `import RFD77402` then it's expecting to find a file called `RFD77402.py` in the search path (which most of the times means just put it in the same directory as main.py). It's case sensitive too.
Some things to try:
- Can you open the REPL (serial console) on the device and run
import os
os.listdir()
That will confirm that the file is there. If not, you'll have to figure out how to get uPyCraft to copy the file alongside main.py.
- If the file is there, try running
import RFD77402
Post by dhylands » Thu May 23, 2019 3:39 pm
The search path for importing is found in sys.path
giants
Post by giants » Thu May 23, 2019 4:41 pm
Thank you soo much for the help.
Sergio
