MemoryError on importing large files
chrizztus
Post by chrizztus » Mon May 20, 2019 12:33 pm
Hi community,
for a robotic project I build a python framework consisting of several files. The files implement the robots behaviour, mainly line following and sensing colors. When I upload these files and run the code everything works fine.
Since the framework is a work-in-progress framework we every once in a while need to provide an update for the framework. So we wrote a script that concatenates all python files into one large file and removes redundant imports. This time the import fails with a memory error:
>>> from mybot import *
MemoryError:
or even
>>> from mybot import MyBot
MemoryError: memory allocation failed, allocating %u bytes
The size of the file is 17 kB and micropython is being run on a nrf52 microcontroller.
Can somebody please explain to me whe memory allocation fails for one large file but not for several small ones (having the same content)?
Kind regards
Christian
Re: MemoryError on importing large files
Post by dhylands » Mon May 20, 2019 1:04 pm
It's because the large file needs to be compiled into bytecode. When the smaller files are being compiled the compilation process takes less memory with the smaller files.
You could also try pre compiling the large python file into a .mpy file (using mpy-cross) and uploading the .mpy file.
Post by jimmo » Mon May 20, 2019 1:06 pm
And if it's an option for you, try freezing the rarely-changing modules into a firmware build. (By putting the code in boards/<BOARD>/modules). This means that they'll execute from ROM, saving even more RAM for your main program.
chrizztus
Post by chrizztus » Mon May 20, 2019 2:09 pm
I understand. With pre compiling everything works as expected and regarding to mem_free() I additionally saved 1300 bytes of RAM :idea:
chrizztus
Post by chrizztus » Mon May 20, 2019 2:14 pm
Thanks jimmo. We usually try to freeze python modules, especially if it concerns our own modules we can release with a firmware update. But, since this is a project for a customer, we have the requirement of keeping all modules updateable.
Regards
Christian
