how find a word in txt file
mehdi_ziyaei
Post by mehdi_ziyaei » Fri May 24, 2019 12:55 am
hi all .i want to find essid and password in my txt file and change my wifi config.
def wifi_connect():
file = open("setting.text" , "r")
wifi_essid =re.sub(r'[w_e=]+.+\n$'," ",file.read())
print(wifi_essid)
sta_if.active(True)
sta_if.connect(wifi_essid,wifi_password)
return
and my setting.text
"\n -----------Time----------- \n t=(2019,5,23,4,40,00,4,143) \n -----------Wifi----------- \n w_e=any-wifi-name \n w_p=any-wifi-password \n ----------Wifi_new---------- \n w_n_e=wifi_name \n w_n_p=wifi_password \n ---------Nodemcu_wifi--------- \n n_e=KENOK KENOK \n n_p=123456789000 \n -----------End----------- \n"
w_e=any-wifi-nam
-----------Wifi_new-----------
w_n_e=wifi_name
w_n_p=wifi_password
-----------Nodemcu_wifi-----------
n_e=KENOK KENOK
n_p=123456789000
i want to find w_e=********** . only star(any wifi essid) Without w_e= .
how find??? my code not work .how fix it ?
Re: how find a word in txt file
Post by jimmo » Fri May 24, 2019 1:57 am
Does your board have `ujson` (I'm pretty sure it will)
import ujson
config = {'essid': 'hello', 'password': 'secret'}
ujson.dump(config, open('config.txt', 'w'))
>>> ujson.load(open('config.txt', 'r'))
{'password': 'secret', 'essid': 'hello'}
(Sorry I didn't answer your actual question, but doing this with regular expressions is way more complicated)
mehdi_ziyaei
Post by mehdi_ziyaei » Fri May 24, 2019 9:19 am
My essid and password are always changing. So I think I should use the re library
Post by jimmo » Fri May 24, 2019 10:31 am
That doesn't matter - the file is still a text file that you can edit.
It'll be a different format to your current one but still just as easy to edit.
Post by dhylands » Fri May 24, 2019 1:56 pm
I normally just use a python file called something like config.py which contains
SSID = "myssid"
password = "mypassword"
and then you can just import config and use config.SSID and config.password
If you want to store new passwords programmatically, just write out a new file.
