how run IRQ() IN IRQ()
I want to run the next function by knock sensor
i have a knock sensor when in the main function , toch it run next function and in next function i have use irq().but not work irq in secend function. how fix it ???
num_knock = 0
def main():
P5 = Pin(5, Pin.IN)
P5.irq(trigger=Pin.IRQ_RISING , handler=enter_password ) //ONE IRQ
def enter_password(P):
print("enter password starting")
p5 = Pin(5, Pin.IN)
door_password=""
for i in range(5):
global num_knock
num_knock = 0
chk_time = utime.time() + 12
while utime.time() <= chk_time:
p5.irq(trigger=Pin.IRQ_RISING , handler=callback ) //TWO IRQ - BUT NOT WORK
door_password += str(num_knock )
return
def callback(p):
global num_knock
if num_knock < 9 :
num_knock += 1
led_num_knock = Pin(4, Pin.OUT)
led_num_knock.on()
utime.sleep_ms(200)
led_num_knock.off()
return
num_knock = 0
def main():
P5 = Pin(5, Pin.IN)
p5 = Pin(5, Pin.IN)
door_password=""
for i in range(5):
global num_knock
num_knock = 0
return
def callback(p):
global num_knock
if num_knock < 9 :
num_knock += 1
led_num_knock.on()
utime.sleep_ms(200)
led_num_knock.off()
return
Re: IRQ() IN IRQ()
irq handlers need to be very short - you want them to do the minimal processing possible.
Can you try instead making the irq handler only record the time that the event happened, and then have your main program detect when these flags have been set and do the actual user input etc.
The other option is to take a look at micropython.schedule
Re: IRQ() IN IRQ()
Also, once you set an IRQ on a pin, it stays on - you code will be continually adding the same callback to the pin.
Can you explain what your code needs to do (i.e. what is the sequence of knocks it needs to detect) and I can help you modify it.
Re: IRQ() IN IRQ()
Hi. I can not speak English well.
I want the device to be in standby mode and run enter_password() function by knock.
by one knock ,enter_password() starting .after finish go to standby mode and wait for new knock to run again enter_password() .
Re: IRQ() IN IRQ()
num_knock = 0
def main():
P5 = Pin(5, Pin.IN)
P5.irq(trigger=Pin.IRQ_RISING , handler=enter_password() ) //ONE IRQ :!:
p5 = Pin(5, Pin.IN)
door_password=""
for i in range(5):
global num_knock
num_knock = 0
p5.irq(trigger=Pin.IRQ_RISING , handler=callback ) //TWO IRQ - BUT NOT WORK :?:
return
def callback(p):
global num_knock
if num_knock < 9 :
num_knock += 1
led_num_knock.on()
utime.sleep_ms(200)
led_num_knock.off()
return
Re: IRQ() IN IRQ()
No problem, your English is fine
What sequence of knocks does your program need to detect? Is it just 5 quick knocks, or does there need to be a pattern?
Another way to think about the problem -- if you had somehow a list that recorded the times when the last N knocks were detected, could you write a function that returned True if it was the correct "password"?
Re: IRQ() IN IRQ()
by one knock must run enter_password() And get the password from the user by 5 loop .every one loop give 1 or 2 or ...or 9 knock .
for ex:
1knock >> run app >> run enter_password()
for i range 4 >> 5 loop
loop 1 >>1knock >>my pass >> 1
loop 2 >> 7knock >>my pass >> 17
loop3 >> 4knock >>my pass >> 174
loop 4 >> 0knock >>my pass >> 1740
loop 5 >> 2knock >>my pass >> 17402
my pass >> 17402
if ok >> open door #serach by another function in my db and return ok or not ok
else >> nothing
and go to standby and wait for 1 knock to run app and again and again .
tnx google translate
for ex:
my pass >> 17402
else >> nothing
Re: IRQ() IN IRQ()
OK, makes sense. FYI, this is actually quite a difficult problem.
The way to think about problems like this is with a thing called a "state machine". The idea is that your program can be in some state, and inputs cause it to move to the next state. An input is something like "a knock", or "some time elapsed". There's lots of good information online about this.
Your program will have states like "waiting", "counting knocks", etc. If a certain amount of time passes, then it should move from one state to the next (e.g. onto the next set of knocks for the next digit of the password). Or if a knock happens then it should do the right thing for the given state.
But all the IRQ handler has to do is set a flag to say that the knock was detected. Then it's up to the state machine in the main loop to figure out what to do with that.
I would start with a simple program that can just count the number of knocks it's seen. Then make it stop counting and reset if there's a delay of more than 2 seconds. Then make it remember the sequence of counts.
Re: IRQ() IN IRQ()
Just another note from your code:
This should be
(You're want to set the handler to the function "enter_password". If you include the "()", then you're setting it to whatever enter_password returns.)
Re: how run IRQ() IN IRQ()
I worked on it for 24 hours. I tried different ways. I think this is the best way. How do I fix it?
I started micropython in about a month and I do not have enough information.
how use flag for my app??
when one irq run by knock , secend irq not work.
i use
pin_starter= Pin(5 ,Pin.IN ,handler = enter_password() ,trigger = Pin.IRQ_RISING)
instead of
but not work.only run enter_password function and after the end of the function, it does not run again and send error for me about arg...
next i use while
def main():
knock_pin = Pin(5, Pin.IN)
if knock_pin .value()==1:
enter_password()
print(" oh my god plssssssss work goood ")
return
But sometimes it works well and sometimes works badly
And one more point
when use only second irq ,
The second irq is always active and calls the callback function with a knock detection
i use
instead of
next i use while
def main():
enter_password()
return
And one more point
