how run IRQ() IN IRQ()
Re: how run IRQ() IN IRQ()
Post by jimmo » Tue Jun 04, 2019 1:28 am
mehdi_ziyaei wrote:
Tue Jun 04, 2019 1:04 am
pin_starter= Pin(5 ,Pin.IN ,handler = enter_password() ,trigger = Pin.IRQ_RISING)
You need to not have the "()" after enter_password.
pin_starter= Pin(5 ,Pin.IN ,handler = enter_password ,trigger = Pin.IRQ_RISING)
(Otherwise this is the same as using the `irq` function later.
The second irq is always active and calls the callback function with a knock detection
Yes. That's how it works - once you register an IRQ, it is always active. You should only do this once.
I'm sorry this isn't an easy problem you're trying to solve.
Can you start with a simpler problem. For example, forget about IRQs, just write a program that counts the number of times a knock has happened. It will look something like:
num_knocks = 0
knock_pin = Pin(5, Pin.IN)
  # Look at the pin value and see if it's changed.
  # If it has, add one to the counter and print it out.
mehdi_ziyaei
Post by mehdi_ziyaei » Tue Jun 04, 2019 2:25 pm
like this ????
def new_enter_password():
    door_password=""
    knock_count = 0
    p5 = Pin(5, Pin.IN)
    for i in range(5):
        knock_count = 0
        print("range %i"%i)
        chk_time = utime.time() + 10
        while utime.time() <= chk_time:
            if p5.value()==1:
                knock_count += 1
                print(knock_count)
        door_password += str(knock_count)
        print("door password = " + door_password)
    print("end")
    door_password=""
    knock_count = 0
    p5 = Pin(5, Pin.IN)
    for i in range(5):
        knock_count = 0
        print("range %i"%i)
            while p5.value()==1:
                knock_count += 1
                print(knock_count)
    print("end")
result very bad .Counters were counted most of the time
by one knock count is 4536 .
i use sleep time for fix .not work
    door_password=""
    knock_count = 0
    p5 = Pin(5, Pin.IN)
    for i in range(5):
        knock_count = 0
        print("range %i"%i)
            if p5.value()==1:
                knock_count += 1
                print(knock_count)
                utime_sleep(1)
    print("end")
Screenshot (57).png (154.74 KiB) Viewed 1858 times
mehdi_ziyaei
Post by mehdi_ziyaei » Tue Jun 04, 2019 6:28 pm
import utime
import os
import re
num_kenok = 0
def main():
    starter= Pin(5, Pin.IN)
        if starter.value()==1:
            print("enter password fun")
            led_on_off(3,600)
            p5 = Pin(5, Pin.IN)
            door_password=""
            for i in range(5):
                global num_kenok
                num_kenok = 0
                chk_time = utime.time() + 12
                    p5.irq(trigger=Pin.IRQ_RISING ,  handler=callback )
                door_password += str(num_kenok)
                led_on_off(1,500)
            led_on_off(5,300)
            find_password(door_password)
    return
def led_on_off(lp,sleep_time):
    led = Pin(2, Pin.OUT)
    for i in range(lp):
        led.off()
        utime.sleep_ms(sleep_time)
        led.on()
    return
def callback(p):
    global num_kenok
    if num_kenok < 9 :
        num_kenok += 1
        led_num_kenok = Pin(4, Pin.OUT)
        led_num_kenok.on()
        utime.sleep_ms(200)
        led_num_kenok.off()
    return
def find_password(f_password):
        print(f_password)
      #  log_write("find_password  - start to find user and password ")
        f_username =""
        with open("user_list.text" , "r") as file:
            for line in file:
                if line.startswith("d_pass="+f_password+" d_user="):
                    line = line.strip()
                    f_username = line[20:]
                    break
        file.close()
        if f_username.strip():
         #   log_write("find_password  - find user and password ")
            print("ok")
         #   log_write("find_password  - not find user and password ")
            print("not ok")
        return
main and enter_passwort >> main function
is ok but Sometimes the amount of the starter is not zero and remains running
