Call method and passed as a parameter
giants
Post by giants » Sat Jun 15, 2019 10:50 am
Hi there !
Here i'm for ask a help. I start to wrote my first own class but gave me this error : AttributeError:'fd77? object has no attribute 'scan'
I don't understand where the problem is. I post a little part of the code here .
Library :
class rfd77(object):
def __init__ (self , data, clock):
self.clock = clock
self.data = data
print(clock)
print(data)
device = i2c.scan()
print (device)
def scan(self):
i2c.readfrom_mem_into(0x4C,0x28,buf)
print(buf[1])
print(buf[0])
Code:
import RFD77402
from time import sleep
dist = rfd77 (5,4)
dist.scan()
So if i call dis = fd77(5,4) work no problem when i call the method gave me the problem ,, another thing i don't understand is because
if i wrote this
i2c = I2C(-1, scl=Pin(self.clock), sda=Pin(self.sda), freq=400000)
doesn't work
Thank you so much
Sergio
Re: Call method and passed as a parameter
Post by jimmo » Sat Jun 15, 2019 11:21 am
Can you post a more complete example of the code (ideally the whole file). I'm unsure where you're putting this line
The general convention for drivers is to have the constructor take an instance of I2C (or SPI, etc), rather than the pins directly. This gives the user of the class more flexibility, and also makes it easier to support different board types.
For example, https://github.com/micropython/micropyt ... ssd1306.py
class SSD1306_I2C(SSD1306):
    def __init__(self, width, height, i2c, addr=0x3c, external_vcc=False):
        self.i2c = i2c
Then I use this with:
from machine import I2C, Pin
from ssd1306 import SSD1306_I2C
i2c =  I2C(scl=Pin(4), sda=Pin(5), freq=400000)
display = SSD1306_I2C(128, 64, i2c)
giants
Post by giants » Sun Jun 16, 2019 7:14 am
Hi ,
this is my library just start to grow up:
from micropython import const
""" Costanti """
ICSR = const(0x00)IER = const(0x02)
Cmd_R = const(0x04)
Dev_Status_R = const(0x06)
Rslt_R = const(0x08)
RsltCnfdR = const(0x0A)
Cmd_CfgR_A = const(0x0C)
Cmd_CfgR_B = const(0x0E)
H2M_mbx = const(0x10)
M2H_mbx = const(0x12)P
MU_Cfg = const(0x14)
I2C_Ad_ptr = const(0x18)
I2C_Data_port = const(0x1A)
I2C_Init_cfg = const(0x1C)
MCPU_PM_Ctrl = const(0x1E)
HFCfg_0 = const(0x20)
HFCfg_1 = const(0x22)
HFCfg_2 = const(0x24)
HFCfg_3 = const(0x26)
Mod_Chip_ID = const(0x28)
Ptch_MCfg = const(0x2A)
""" Variabili """
buf = bytearray(6)
self.clock = clock
self.data = data
i2c = I2C(-1, scl=Pin(self.clock), sda=Pin(self.data), freq=400000)
print(clock)
print(data)
device = i2c.scan()
print (device)
def scan(self):
self.i2c.readfrom_mem_into(0x4C,0x28,buf)
print(buf[1])
print(buf[0])
CODE:
import RFD77402
dist = rfd77 (5,4)
dist.scan()
This is all my code for the moment, i state to move the first step in python and really some times i have a lot of doubt ., for luck this forum help me a lot. Can you help me to understand because when i call dis.scan() gave me an error i wrote in the fist post ? . I saw your file thank you now i print and i study.
Have a good day
Sergio
Post by jimmo » Sun Jun 16, 2019 10:48 am
Inside `def scan()`, it refers to self.i2c, but you in `__init__`, the code never sets `self.i2c`.
So you need to change it to:
    self.clock = clock
    self.data = data
    print(clock)
    print(data)
    device = self.i2c.scan()
    print (device)
But I recommend changing it to take the i2c instance, rather than the individual pins
  def __init__ (self , i2c):
    self.i2c = i2c
    print (device)
then when you use your rfd77 class:
dist = rfd77 (I2C(-1, scl=Pin(self.clock), sda=Pin(self.data), freq=400000) )
dist.scan()
giants
Post by giants » Sun Jun 16, 2019 3:10 pm
i try to did but the first part work the scene doesn't this is the error compiler wrote to me
download ok
exec(open('main.py').read(),globals())
[76]
File "<string>", line 15, in <module>
AttributeError: 'rfd77' object has no attribute 'scan'
Post by jimmo » Sun Jun 16, 2019 5:47 pm
Is your scan method indented the same as __init__ ? (i.e. the same number of spaces in front of it). Sorry I can't tell because the formatting is lost.
When you past code into the forum, select it and then press the </> button so the formatting is preserved.
giants
Post by giants » Sun Jun 16, 2019 8:37 pm
""" Costanti """
Cmd_R = const(0x04)
""" Variabili """
buf = bytearray(6)
    self.i2c = i2c
    print (device)
    def scan(self):
    print(buf[1])
    print(buf[0])
dist.scan()
giants
Post by giants » Sun Jun 16, 2019 8:38 pm
and this is the message gave to me
download ok
[76]
Thank you
Post by jimmo » Sun Jun 16, 2019 10:00 pm
Sorry I meant like this:
    self.i2c = i2c
    print (device)
  def scan(self):
    print(buf[1])
    print(buf[0])
giants
Post by giants » Mon Jun 17, 2019 6:10 am
Please forgive me
i wrote in your same way but still doesn't work :cry: :cry: :cry:
same error
download ok
[76]
I use UPyCraftv1.1 do you use other software ? really i don't understand
Sergio
