Call method and passed as a parameter
Hi there !
Here i'm for ask a help. I start to wrote my first own class but gave me this error : AttributeError:'fd77? object has no attribute 'scan'
I don't understand where the problem is. I post a little part of the code here .
Library :
class rfd77(object):
def __init__ (self , data, clock):
self.clock = clock
self.data = data
print(clock)
print(data)
device = i2c.scan()
print (device)
def scan(self):
i2c.readfrom_mem_into(0x4C,0x28,buf)
print(buf[1])
print(buf[0])
Code:
import RFD77402
from time import sleep
dist = rfd77 (5,4)
dist.scan()
So if i call dis = fd77(5,4) work no problem when i call the method gave me the problem ,, another thing i don't understand is because
if i wrote this
i2c = I2C(-1, scl=Pin(self.clock), sda=Pin(self.sda), freq=400000)
doesn't work
Thank you so much
Sergio
Library :
self.clock = clock
self.data = data
print(clock)
print(data)
device = i2c.scan()
print (device)
def scan(self):
print(buf[1])
print(buf[0])
Code:
import RFD77402
dist = rfd77 (5,4)
dist.scan()
if i wrote this
doesn't work
Thank you so much
Sergio
Re: Call method and passed as a parameter
Can you post a more complete example of the code (ideally the whole file). I'm unsure where you're putting this line
The general convention for drivers is to have the constructor take an instance of I2C (or SPI, etc), rather than the pins directly. This gives the user of the class more flexibility, and also makes it easier to support different board types.
For example, https://github.com/micropython/micropyt ... ssd1306.py
Then I use this with:
class SSD1306_I2C(SSD1306):
def __init__(self, width, height, i2c, addr=0x3c, external_vcc=False):
self.i2c = i2c
from machine import I2C, Pin
from ssd1306 import SSD1306_I2C
i2c = I2C(scl=Pin(4), sda=Pin(5), freq=400000)
display = SSD1306_I2C(128, 64, i2c)
Hi ,
this is my library just start to grow up:
from micropython import const
""" Costanti """
ICSR = const(0x00)IER = const(0x02)
Cmd_R = const(0x04)
Dev_Status_R = const(0x06)
Rslt_R = const(0x08)
RsltCnfdR = const(0x0A)
Cmd_CfgR_A = const(0x0C)
Cmd_CfgR_B = const(0x0E)
H2M_mbx = const(0x10)
M2H_mbx = const(0x12)P
MU_Cfg = const(0x14)
I2C_Ad_ptr = const(0x18)
I2C_Data_port = const(0x1A)
I2C_Init_cfg = const(0x1C)
MCPU_PM_Ctrl = const(0x1E)
HFCfg_0 = const(0x20)
HFCfg_1 = const(0x22)
HFCfg_2 = const(0x24)
HFCfg_3 = const(0x26)
Mod_Chip_ID = const(0x28)
Ptch_MCfg = const(0x2A)
""" Variabili """
buf = bytearray(6)
self.clock = clock
self.data = data
i2c = I2C(-1, scl=Pin(self.clock), sda=Pin(self.data), freq=400000)
print(clock)
print(data)
device = i2c.scan()
print (device)
def scan(self):
self.i2c.readfrom_mem_into(0x4C,0x28,buf)
print(buf[1])
print(buf[0])
CODE:
import RFD77402
dist = rfd77 (5,4)
dist.scan()
This is all my code for the moment, i state to move the first step in python and really some times i have a lot of doubt ., for luck this forum help me a lot. Can you help me to understand because when i call dis.scan() gave me an error i wrote in the fist post ? . I saw your file thank you now i print and i study.
Have a good day
Sergio
""" Costanti """
Cmd_R = const(0x04)
""" Variabili """
buf = bytearray(6)
self.clock = clock
self.data = data
print(clock)
print(data)
device = i2c.scan()
print (device)
def scan(self):
print(buf[1])
print(buf[0])
CODE:
import RFD77402
dist = rfd77 (5,4)
dist.scan()
Have a good day
Sergio
Inside `def scan()`, it refers to self.i2c, but you in `__init__`, the code never sets `self.i2c`.
So you need to change it to:
But I recommend changing it to take the i2c instance, rather than the individual pins
then when you use your rfd77 class:
self.clock = clock
self.data = data
print(clock)
print(data)
device = self.i2c.scan()
print (device)
def __init__ (self , i2c):
self.i2c = i2c
print (device)
dist = rfd77 (I2C(-1, scl=Pin(self.clock), sda=Pin(self.data), freq=400000) )
dist.scan()
i try to did but the first part work the scene doesn't this is the error compiler wrote to me
download ok
exec(open('main.py').read(),globals())
[76]
File "<string>", line 15, in <module>
AttributeError: 'rfd77' object has no attribute 'scan'
download ok
[76]
Is your scan method indented the same as __init__ ? (i.e. the same number of spaces in front of it). Sorry I can't tell because the formatting is lost.
When you past code into the forum, select it and then press the </> button so the formatting is preserved.
""" Costanti """
Cmd_R = const(0x04)
""" Variabili """
buf = bytearray(6)
self.i2c = i2c
print (device)
def scan(self):
print(buf[1])
print(buf[0])
dist.scan()
and this is the message gave to me
Thank you
download ok
[76]
Sorry I meant like this:
self.i2c = i2c
print (device)
def scan(self):
print(buf[1])
print(buf[0])
Please forgive me
i wrote in your same way but still doesn't work
same error
I use UPyCraftv1.1 do you use other software ? really i don't understand
Sergio
same error
download ok
[76]
Sergio
