MicroWebSrv
jdcrunchman
MicroWebSrv
Post by jdcrunchman » Wed Jul 24, 2019 5:21 pm
* Exact steps to cause this issue
1. First I did this...
I activated the WLAN and Hot Spot.
## Set up the Access point
ap = network.WLAN(network.AP_IF)
ap.ifconfig(('192.168.84.1', '255.255.255.0', '192.168.84.1', '192.168.84.1')) # ip, netmask, gateway, dns
ap.active(True)
ap.config(essid='aWhisper', authmode=network.AUTH_WPA_WPA2_PSK, password='')
2. Then, I did that...
I ran the original main.py code from the github
then I went to my laptop, and connected to the WIFI, then I checked network connectivity
by sending a test ping. The Ping worked just fine.
Then, using the browser on the Mac, and pointed it to: http://192.168.84.1/index.html
The startup screen came up just fine.
But when I went to another page, I get a 405 error.
Is there anyway I can trace through the server code and turn on some server logging, so I can
try and debug why this doesn't work?
I'm sending the full ZIP of all the HTML, IMG, CSS files
[WhisperMagicMessagingUI.zip](https://github.com/pycom/pycom-micropyt ... gingUI.zip)
This is my main entry code I run, right after the boot.py.
mainSetup.py - I run this right after the boot.py
### Setup the WLAN
wlan = network.WLAN(network.STA_IF) # create station interface
wlan.active(True) # activate the interface
myscan = wlan.scan() # scan for access points
wlan.isconnected() # check if the station is connected to an AP
print ("WLAN Setup")
### Set up the Access point
ap.active(True)
ap.config(essid='aWhisper', authmode=network.AUTH_WPA_WPA2_PSK, password='my-password')
print ("Access point setup - IP = " + "192.168.84.1")
print ("creating an array of table values")
mytable = [['john', "not listening", "36db"], ['andy', 'Online', '56db']]
print ("Now run mainweb.py to start the server")
import mainweb
Then run "mainweb.py" below
from microWebSrv import MicroWebSrv
from trace import bp
#bp('testing', (1,2,3,5)[3], 3**5)
@MicroWebSrv.route('/test')
def _httpHandlerTestGet(httpClient, httpResponse) :
content = """\
<!DOCTYPE html>
<html lang=en>
<head>
<meta charset="UTF-8" />
<title>TEST GET</title>
</head>
<body>
<h1>TEST GET</h1>
Client IP address = %s
<br />
<form action="/test" method="post" accept-charset="ISO-8859-1">
First name: <input type="text" name="firstname"><br />
Last name: <input type="text" name="lastname"><br />
<input type="submit" value="Submit">
</form>
</body>
</html>
""" % httpClient.GetIPAddr()
httpResponse.WriteResponseOk( headers = None,
contentType = "text/html",
contentCharset = "UTF-8",
content = content )
@MicroWebSrv.route('/test', 'POST')
def _httpHandlerTestPost(httpClient, httpResponse) :
formData = httpClient.ReadRequestPostedFormData()
firstname = formData["firstname"]
lastname = formData["lastname"]
content = """\
<!DOCTYPE html>
<html lang=en>
<head>
<title>TEST POST</title>
</head>
<body>
<h1>TEST POST</h1>
Firstname = %s<br />
Lastname = %s<br />
</body>
</html>
""" % ( MicroWebSrv.HTMLEscape(firstname),
MicroWebSrv.HTMLEscape(lastname) )
content = content )
@MicroWebSrv.route('/edit/<index>') # <IP>/edit/123 -> args['index']=123
@MicroWebSrv.route('/edit/<index>/abc/<foo>') # <IP>/edit/123/abc/bar -> args['index']=123 args['foo']='bar'
@MicroWebSrv.route('/edit') # <IP>/edit -> args={}
def _httpHandlerEditWithArgs(httpClient, httpResponse, args={}) :
content = """\
<!DOCTYPE html>
<html lang=en>
<head>
<title>TEST EDIT</title>
</head>
<body>
content += "<h1>EDIT item with {} variable arguments</h1>"\
.format(len(args))
if 'index' in args :
content += "<p>index = {}</p>".format(args['index'])
if 'foo' in args :
content += "<p>foo = {}</p>".format(args['foo'])
# bp('content = ', content)
content += """
</body>
</html>
content = content )
def _acceptWebSocketCallback(webSocket, httpClient) :
print("WS ACCEPT")
webSocket.RecvTextCallback = _recvTextCallback
webSocket.RecvBinaryCallback = _recvBinaryCallback
webSocket.ClosedCallback = _closedCallback
def _recvTextCallback(webSocket, msg) :
print("WS RECV TEXT : %s" % msg)
webSocket.SendText("Reply for %s" % msg)
def _recvBinaryCallback(webSocket, data) :
print("WS RECV DATA : %s" % data)
def _closedCallback(webSocket) :
print("WS CLOSED")
#routeHandlers = [
# ( "/test", "GET", _httpHandlerTestGet ),
# ( "/test", "POST", _httpHandlerTestPost )
srv = MicroWebSrv(webPath='/')
srv.MaxWebSocketRecvLen = 256
srv.WebSocketThreaded = False
srv.AcceptWebSocketCallback = _acceptWebSocketCallback
srv.Start()
There are other files in this document as well, such as css, images, and such.
Am I using some feature in my HTML that is not supported on the MicroWebSrv package?
All of the files are in the attached ZIP file.
Thank you!
