MicroPython CAN bus for ESP32
dnhkng
Re: MicroPython CAN bus for ESP32
Post by dnhkng » Fri Mar 05, 2021 10:29 am
Great work! I'm really looking forward to using CAN is some ESP32-Wrover projects. Could you upload the binaries?
wthie
Post by wthie » Sat Mar 06, 2021 8:41 pm
Just confirmed loopback testing ok (rx/tx IO4, IO0) with the file esp32_can.py present in the example folder of fork
https://github.com/nos86/micropython
Make sure to select branch 'esp32-can-driver-harmonization' in the fork mentioned above to get the proper versions of the relevant files.
The binaries I compile are for the LilyGo board family, I'm not sure what's wanted concerning what gets compiled and linked in?
The board configs currently present in MP V1.13 (with uasyncio present) are
  • GENERIC
  • GENERIC_D2WD
  • GENERIC_OTA
  • GENERIC_SPIRAM
  • TINY_PICO
ihornehrutsa
Post by ihornehrutsa » Tue Jun 22, 2021 6:12 am
Shayan
Post by Shayan » Tue Jun 22, 2021 6:45 pm
gregger2k
Post by gregger2k » Thu Jun 24, 2021 4:11 am
WIP: esp32 CAN(TWAI) driver
https://github.com/micropython/micropython/pull/7381
ihornehrutsa I appreciate your working on the patch. I have built the firmware using your fork and have the machine CAN module loaded but I am having trouble to get anything to work. I have explored your updated documentation but I can't get the loopback to work, I just get timeouts on receive.
Do you have some simple examples using the new patch syntax I could try?
Thanks again,
Greg
thalesmaoa
Post by thalesmaoa » Mon Nov 29, 2021 8:18 pm
I've read the topic, but I'm confused.
Pull request is open. That means that CAN is not officially supported yet, correct?
