Page 1 of 4
micropython-lib - "distributed" uPython standard library
Posted: Sat Apr 26, 2014 1:40 pm
by pfalcon
micropython-lib is a community project to build a non-monolithic and lean standard Python library for MicroPython.
Following aims and requirements are set forth:
- To coordinate efforts for implementing standard library modules for MicroPython.
- Be testbed and proof of concept for implementing Python library not as a big monolithic blob unalienably installed with the interpreter, but based on the idea of separately distributed and installable individual modules - just in the same way as 3rd-party modules are distributed and used.
- To bootstrap prototyping support for using standard Python package infrastructure with MicroPython, like pip package manager, PyPI package repository, etc.
- To further develop "unix" port to be useful, and be testbed for idea of implementing as much as possible system integration modules in Python (using FFI (Foreign Function Interface) module), instead of C.
- To be implemented in such way as to be usable for MCU/baremetal ports of MicroPython too.
Initial RFC was in the
ticket #405. Since then, number of modules were published on PyPi, from where they are installable using the
upip tool from the
tools/ folder of the main MicroPython repository. Here's the list of currently published packages:
https://pypi.org/search/?q=micropython
Documentation on installing packages in MicroPython is available at
http://docs.micropython.org/en/latest/r ... kages.html
Re: micropython-lib - "distributed" uPython standard library
Posted: Sat Apr 26, 2014 1:41 pm
by pfalcon
(reserved message)
Posted: Sat Apr 26, 2014 1:56 pm
by pfalcon
(reserved message)
Posted: Sat May 24, 2014 2:51 pm
by pfalcon
Some update report: There's now 230 commits in
https://github.com/pfalcon/micropython-lib . 60 packaged published on PyPI:
https://pypi.python.org/pypi?%3Aaction= ... mit=search
(many are dummy packages just to get imports not fail).
I now try to concentrate on making "bloated" CPython packages run on MicroPython with minimal changes. The bloat they bring is not exciting at all (for example, http.client requires 600K heap just to import, so no chance it'll run on MCU), but it's very important to get "real" Python code to run, to be able that we provide *Python* implementation, and not some weird Python-like language instead.
Testing of published packages is very much needed, consider helping with that.
Posted: Sun May 25, 2014 1:29 pm
by kfricke
Hi! I am personally interested in the hashlib module, which is a dummy for some good reasons. Knowing that this topic and all it's usages and dependencies is a big one, does anyone have a good hint on how to feasibly implement at least the very basic hashing functions (whith focus on sha256 and the other remaining secure hashing algorithms)? I did start to use the SHA256 module from PyPy (linked here:
http://stackoverflow.com/questions/7321 ... -in-python) and slowsha (
https://code.google.com/p/slowsha/) also did cause a hard error on my pyboard
Any hints towards another good starting point are appreciated, thanks!
Posted: Wed May 28, 2014 8:06 pm
by pfalcon
Yeah, and those reasons are that nobody needed it yet - at all, or that much as to work on it
. And then, because it's not clear now to approach it - common sense says that hashing should be implemented in C, but besides finding good license-compatible code, that means also bloating the uPy binaries with functions which only fractions of users will need (especially on MCU). Those are not unsolvable problems, but require more than one head to even decide on approach.
So all in all, I support an idea to start with Python-only implementation. And to get that running, I always suggest using unix port first, because it's more comfortable to use than a board.
I had a look at
https://code.google.com/p/slowsha/ , it surely cannot run directly, I was able to workaround few smaller issues, but then I hit
https://github.com/micropython/micropython/issues/627 . As can be seen, @dpgeorge fixed it today, so interested parties can start looking for further issues
Posted: Fri Jun 06, 2014 8:43 pm
by pfalcon
After few attempts on how to manage metadata for so many modules, I wrote a script to generate setup.py from concise description:
https://github.com/micropython/micropyt ... etadata.py . And now it runs with MicroPython too! It took porting glob module from CPython and implementing "%(key)s" % {} formatting.
Posted: Sun Oct 19, 2014 1:36 am
by salimfadhley
Where do I find the ffi module which is required by the _libc package?
Posted: Sun Oct 19, 2014 2:12 am
by blmorris
salimfadhley wrote:Where do I find the ffi module which is required by the _libc package?
Depending on your OS / distribution you probably need to install it. On OSX I needed to install 'libffi', I assume that it will be called something similar in any given Linux distro.
-Bryan
Posted: Sat Oct 25, 2014 9:58 pm
by Turbinenreiter
How should we go about lib for the pyboard? A lot of the modules don't work on the pyboard, just as an example, pystone doesn't work, but it's an easy fix - I just replaced time.clock with pyb.millis/1000.
btw, the pyboard apparently does 1688 pysteons/second. whatever that means.
Pystone(1.1) time for 50000 passes = 29.6147
This machine benchmarks at 1688.35 pystones/second
