rshell - Remote Shell
yogotech
Re: rshell - Remote Shell
Post by yogotech » Thu Mar 05, 2020 6:05 am
jimmo wrote:
Thu Mar 05, 2020 5:22 am
yogotech wrote:
Thu Mar 05, 2020 4:51 am
How can I do this with rshell, and is there a way to capture the output?
I think the idea is that you use the "repl" command to get to the MicroPtyhon prompt hit Ctrl-D to soft reset (if you've previously loaded this file), then run "import blink"
rshell> repl ~ import blink~
to enter the repl and run the command and then back to rshell.
/pyboard> repl ~ import blink ~
Entering REPL. Use Control-X to exit.
MicroPython v1.12 on 2019-12-20; ESP32 module with ESP32
>>> import blink
ImportError: no module named 'blink'
>>> /pyboard>
No joy. The above may be due to my unfamiliarity with python, as my simple example code is not a class per-se, but it should be easy to just 'run' the file similar to how ampy does.
wr300000
Post by wr300000 » Thu Mar 05, 2020 6:39 am
Normally I use screen to enter REPL. I recently use rshell as IDE
rshell -p /dev/ttyUSB0 --editor nano --buffer-size=30
/home/wr300000> repl <---- get in repl and release machine.reset() to rerun my main.py
Below is result from my main.py showing normal /sd directory and other configured variables.
GC:
37952 total
12256 : 25696
1=84 2=8 m=264
free RAM = 9312 bytes
I2C(PCF8574) LCD not found
free SDcard = 7926009856 bytes
total SDcard = 7931396096 bytes
stack: 2768 out of 8192
GC: total: 37952, used: 12880, free: 25072
No. of 1-blocks: 99, 2-blocks: 8, max blk sz: 264, max free sz: 1457
Thr 5 MAR 2020 - 12:39 UTC+ 7
MicroPython v1.12-195-gb16990425-dirty on 2020-03-03; ESP module with ESP8266
>>> dir()
['winteroff', 'uos', 'sdcheck', 'nettime', 'ppwmstop', 'mem_info', 'clear', 'os', 'sd', 'gc', 'dayl', 'pwordd', 'plow', 'pscl', 'sid', 'esp', 'cat', 'cp', 'platform', 'sdcard', 'pword', 'sleep_ms', 'dlboot', 'machine', 'Pin', 'ssidd', 'sync_ntp', 'i2cPinSCL', 'summeroff', 'I2C', 'now', 'soff', 'webrepl', 'ticks_ms', 'phigh', 'i2cPinSDA', 'bdev', '__name__', 'ppwm', 'delayboot', 'psda', 'daylight', 'woff'] <---- /sd and configured variable are present
>>> os.listdir()
['sd', 'boot.py', 'main.py', 'webrepl_cfg.py', 'confighw.py', 'conf.py', 'board.py'] <---- before ctrl-X
>>> <---- ctrl-X to shell
/home/wr300000> ls /pyboard <---- release rshell list command
board.py conf.py main.py
boot.py confighw.py webrepl_cfg.py <---- /sd and all configured variable gone
>>> dir() <---- /sd and all configured variable gone
['bdev', 'get_stat', '__name__', 'stat', 'uos', 'esp', 'webrepl', 'gc', 'output']
Why did rshell Iist command effect to main.py ?
Post by jimmo » Thu Mar 05, 2020 7:30 am
You also need to cp blink.py to the device.
Post by pythoncoder » Thu Mar 05, 2020 9:04 am
The way I work is as follows. I use a programmers' editor (Kate) to edit a file, say myfile.py. Assume I want to run myfile.main(). From the directory containing the file I run rshell. Let's say the target is a Pyboard with an SD card. At the rshell prompt I issue
path> cp myfile.py /sd
repl
>>> import myfile
>>> myfile.main()
ctrl-x takes you back to rshell.
Note this can be streamlined, so after ctrl-x all you need is an uparrow to run an edited version:
path> cp myfile.py /sd; repl ~ import myfile ~ myfile.main()
yogotech
Post by yogotech » Fri Mar 06, 2020 12:04 am
ARGH, it was on the device, but I must have fat-fingered it.
:evil:
Thanks (I feel stupid now).
yogotech
Post by yogotech » Fri Mar 06, 2020 12:06 am
repl
>>> import myfile
>>> myfile.main()
This would work for me, but many of the example programs I'm using haven't defined a main method, so it appears that just
>>> import myfile
Is probably adequate for them.
[ I still think having a run command would be faster and more intuitive, but I'll quit whining now.... ;) ]
Thanks everyone!
Post by pythoncoder » Fri Mar 06, 2020 6:52 am
I'm not sure what you're advocating but you could look at pyboard.py to see if that fits the bill.
An rshell line like the one I posted (which is easily adapted for your case with no main() function) gives an extremely fast edit-test cycle because of rshell's ability to recall previous lines.
