Page 8 of 9
Re: rshell - Remote Shell
Posted: Sun Jul 19, 2020 7:47 pm
by bukaida
How can I rename remote files/directories using rshell? Is it possible to accommodate any tiny micropython editor within rshell itself, so that external editor is not required?
Also during
it will be helpful if the file name being currently copied, is displayed.
Posted: Mon Jul 20, 2020 7:34 am
Have you studied the rsync command? I appreciate it doesn't do exactly what you want, but it does provide feedback on files copied and will replicate directory structures. It will also cope with directories renamed on the source (using the -m option).
Use with care: it is a powerful tool and can wreak havoc if used incorrectly...
Posted: Mon Jul 20, 2020 8:11 am
by bukaida
Yes Peter, I have tried it, but that is a passive way and sometimes does not produce good results for long names with special characters ( In windows). I was just thinking if we can have something direct as mkdir, rm or cp. For example
may be in the next update ?
Posted: Mon Jul 20, 2020 8:26 am
by Roberthh
You can always rename file on the windows side with windows tools, and on the micropython side with uos.rename() in the REPL prompt. That may not be comfortable, but it works. if you have a device connected by ftp, you can use the ftp mechanisms.
Posted: Mon Jul 20, 2020 8:44 am
There is also
my fork of rshell. This enables the use of text macros. The docs show how to create an
mv macro which moves/renames files by copying and deleting. I guess one could be written to do the same trick for directories using
cp -r and
rm -r. Like
rsync it would have potential for havoc if used incorrectly.
Posted: Sat Feb 27, 2021 7:33 am
by rguillon
rsync and cp commands don't seems to work with symlinks.
I have several devices with different configurations, each device has it's own source dir with the specifics and symlinks to the common sources, in my case DIR1 and DIR2 :
$ rshell cp -r * /pyboard
Using buffer-size of 32
Connecting to /dev/ttyUSB0 (buffer-size 32)...
Trying to connect to REPL connected
Testing if ubinascii.unhexlify exists ... Y
Retrieving root directories ... /boot.py/ /components.py/ /config.py/ /DIR1/ /main.py/ /DIR2/
Setting time ... Feb 27, 2021 08:21:14
Evaluating board_name ... pyboard
Retrieving time epoch ... Jan 01, 2000
Source is a file not a directory.
$ rshell rsync . /pyboard
Retrieving root directories ... /boot.py/ /components.py/ /config.py/ /DIR1/ /drivers.py/ /main.py/ /DIR2/
Setting time ... Feb 27, 2021 08:21:57
Checking /pyboard/main.py
Checking /pyboard/components.py
Checking /pyboard/config.py
Checking /pyboard/boot.py
Source '/some_directory/DIR1' is a file and destination '/pyboard/DIR1' is a directory. Ignoring
Source '/some_directory/DIR2' is a file and destination '/pyboard/DIR2' is a directory. Ignoring
I could get the list of files with find -L and call rshell for each one, but it's pretty slow.
Is there a smarter workaround?
I suggest macros
Posted: Sat Feb 27, 2021 2:45 pm
As mentioned above, I have a fork of
rshell providing text macros documented
here. The macros can be arranged to load when
rshell starts. I have an alias for each project which exports an environment variable: this ensures that
rshell imports a set of macros for that project when it starts up. I can then issue (say)
which changes to the correct source directory and performs an
rsync to (in this case)
/pyboard/drivers. You could define a macro for each of your standard directories.
The macro facility has transformed my use of rshell: it saves a lot of errors and greatly simplifies the maintenance of multiple bigger projects.
Posted: Sat Feb 27, 2021 9:19 pm
by dhylands
I've uploaded version 0.2.29 of rshell.
cp and rsync should work properly with symbolic links.
This version also supports the Raspberry Pi Pico (and I've removed my pico branch)
Posted: Sun Feb 28, 2021 4:36 pm
Very nice.
Posted: Sun Feb 28, 2021 4:40 pm
by kevinkk525
Awesome, thank you.
