Are there any modules/libraries that could easily create Menus on displays? I'm planning to use a menu to execute my other python files on the storage. Currently, I'm using a web page to do this but its very slow since it has to connect to a wifi network and i would have to open the page to select which file to run
So, basically i want to create a menu on the display that i could control with buttons to select a python code to run
Create Menus on display (I2C SSD1306 OLED on ESP32)
Re: Create Menus on display (I2C SSD1306 OLED on ESP32)
There is this nano-GUI which should work with SSD1306.
I might try this, I already made my own menus but it looks ugly so might try this instead
also, do you know any way to scroll the framebuffer horizontally or vertically? I tried using framebuf.FrameBuffer.scroll() but I'm not sure what the correct arguments is.
See the docs. The args are pixels which may be +ve or -ve depending on direction of scroll.
I find the method non-ideal because the exposed region is not erased. This is a deliberate, documented, design decision.
