OLED Library Writer, Clear to end of line
Re: OLED Library Writer, Clear to end of line
Post by pythoncoder » Mon Mar 02, 2020 10:52 am
Well done :D
Without seeing code or docs for the display driver it's hard to comment, but one that doesn't support drawing a filled rectangle strikes me as extraordinarily limited. However given that you can evidently blit glyphs, you could presumably blit a framebuf crafted to correspond to the dimensions of the field. That might enable you to implement my solution. But yours works, so there's not really any need.
stanely
Post by stanely » Mon Mar 02, 2020 1:42 pm
The displays I'm using are the Nokia 5110, the SSD1306 0.96" OLED, and the MX1230. I don't expect to be doing much GUI with these; It's all text.
My approach is in the style of the Python 'curses' package which provides for an addressable cursor on a VT100-style display. That's kind of what Writer is doing, except it adds a lot of font flexibility. So in 'curses' there's this:
window.clrtoeol()
Erase from cursor to the end of the line.
It's very efficient and does what's needed. Best thing about my solution is that I only had to write 2 lines of code and copy the other 8. :)
