Using Ethernet on the ESP32
Maxi
Post by Maxi » Wed Feb 05, 2020 1:52 pm
Hello everybody,
I'm using a ESP32 with an LAN8710A-EZC similare to an Olimax board (https://www.olimex.com/Products/IoT/ESP ... e-hardware). On the board is running MicroPython 1.12-137. To initialize the Ethernet connection I use the following code:
LAN = network.LAN(mdc = Pin(23), mdio = Pin(18), power = None, phy_type = network.PHY_LAN8720, clock_mode=network.ETH_CLOCK_GPIO0_IN, phy_addr=0)
LAN.active(1)
When running the code I can see this on the console:
I (501867) emac: emac reset done
I (501867) ethernet: start
True
>>> I (505867) ethernet: LAN cable connected
I (506897) event: eth ip: 192.168.0.6, mask: 255.255.255.0, gw: 192.168.0.1
I (506897) ethernet: Got IP
And then the esp32 stops running and I have to tipp something in the console the get back in the repl. The board is now connected to the Internet but the following code stops.
Hope someone can help me!
Greetings
Maxi
Online
Re: Using Ethernet on the ESP32
Post by jimmo » Thu Feb 06, 2020 1:24 am
I the problem here that MicroPython prints out the ">>>", but then the IDF prints out the logging message, making it look like you're not at the prompt anymore. i.e. does just pressing enter (which will make MicroPython print the ">>>" again) solve the issue?
What do you mean by "the following code stops"? Does code work if you type it at the REPL?
Maxi
Post by Maxi » Thu Feb 06, 2020 9:41 am
With following code I mean code that is in my main.py after LAN.active(1)
for example:
LAN.active(1)
print('Connected')
The print command is not executed.
Maxi
Post by Maxi » Thu Feb 06, 2020 10:28 am
ok, sorry I just dopple checked it and it just work fine :oops:
