I built a 16x16 matrix cutting and connecting the strip.
The strip sometimes turn on some random led at random color and brightness. I have enough power and all the strip parts is well connected.
This is the fps manager of the game. It's 10fps, so nothing to heavy i think. (Edit: i tried to update every 1second, but random pixel persist but they are less frequent)
def fps(timer):
global moved, snake_speed
if (moved > snake_speed):
moved = 0
updateSnake()
moved += 1
drawSnake()
drawFood()
neopixelhelper.show()
def start():
global timer
timer = machine.Timer(0)
timer.init(period=100, mode=machine.Timer.PERIODIC, callback=fps)
random.seed(utime.time())
drawFood()
drawSnake()
Here is a photo of my circuit:
Edit: I tried to put a 500ohm resistor between pin4 and data input without luck.
and here's the video of the behaviour:
https://youtu.be/qujBUNlemLs
Thank you for any suggestion
