DS18B20 --- Reading while getting other chores done
doceave
Post by doceave » Mon Feb 17, 2020 1:31 pm
Hi there
I find myself in a situation where this is to expensive, in terms of time, to execute:
There is only need to check temperature every 2 sec or so, however, during the 750ms above the ESP32 needs to be reading values from an ADC and making decisions based on this every 100ms ---- I.E. The program cannot wait around for 750ms.
Would it be possible to use timer based callbacks to initiate scanning, and another to read values 750ms later? Perhaps an expert would consider the code below and let me know what's wrong with it?
def (scan_ow):
global roms
tim.init(period=750, mode=Timer.ONE_SHOT, callback=read_ow)
def (read_ow):
global roms
tim = Timer(-1)
tim.init(period=1000, mode=Timer.PERIODIC, callback=scan_ow)
I = 0
latest_temp = 0
roms = 0
# Do other import stuff...
# ...like count to infinity...
pass
pass
pass
pass
pass
time.sleep_ms(1000)
print (I)
I = I + 1
I only expect a stock of DS18B20's to arrive in the next few days. Help in the interim would be greatly appreciated.
Re: DS18B20 --- Reading while getting other chores done
Post by Roberthh » Mon Feb 17, 2020 2:35 pm
You can of course start the temperature measurement, do something else and read back the value later. There is no maximum wait time, just a minimum, depending on the chosen resolution.
Post by jimmo » Tue Feb 18, 2020 2:07 am
The simplest way to rethink this is on (say a 50ms) interval:
n = 0
  if n == 30:
    n = 0
  if n % 2 == 0:
    # this happens every 100ms
  if n % 15 == 0:
    # this happens every 750ms
    # get result from previous scan
    # start new scan
Some sort of state machine would be useful here, using the current time to detect when things should happen. i.e. busy loop until the next time is up.
But really, what you probably want is asyncio. Create two tasks:
import asyncio
async def adc_task():
    # do adc stuff
    await asyncio.sleep_ms(100)
async def ds18x20_task():
    # start scan
    await asyncio.sleep_ms(750)
    # finish scan
async def main():
  t1 = asyncio.create_task(adc_task())
  t2 = asyncio.create_task(ds18x20_task())
  await t1
  await t2
asyncio.run(main())
(This is (untested, written on my phone, sorry) based the Python 3.8 API, which is supported by "new" uasyncio -- https://github.com/micropython/micropython/pull/5332 -- but could be adapted to the existing version on micropython-lib)
See https://github.com/peterhinch/micropython-async/ and https://github.com/peterhinch/micropyth ... UTORIAL.md
Note: if it's very important that your ADC samples are _exactly_ 100ms apart, then you'll have to do smarter things, but this is a good base to work on -- it's well worth investigating asyncio.
tve
Post by tve » Tue Feb 18, 2020 5:18 am
Also consider that 750ms is for a 12-bit reading, which I believe is overkill. I always use 10-bit resolution, which takes much less time and I feel represents about the best accuracy you can get unless you calibrate each individual sensor and pay extremely careful attention to how you transfer heat to the device in your mount...
doceave
Post by doceave » Tue Feb 18, 2020 7:52 pm
Jimmo!! :) This uasyncio appears to be the ideal solution albeit way above my level....
I have installed the standard MicroPython v1.12 (2019-12-20) with IDF3
Thus far I have managed to do the following:
> Install the uasyncio library using these instructions --- https://github.com/peterhinch/micropyth ... bare-metal
--- No error on importing of uasyncio so I assume this has been done correctly (4 files copied with corresponding folder structure)
> Copy the adapted script to the ESP32
import uasyncio as asyncio
from time import sleep_ms, ticks_ms
pass
pass
print ("Doing ADC things......")
print ("Doing temperature things: Starting Scan....")
print ("Doing temperature things: Reading Temperatures....")
async def main():
await t1
await t2
asyncio.run(main())
Sadly it would appear that I have not adapted the code well enough as the following error results on running (on the last line of code):
>>> import fast_temp
File "fast_temp.py", line 23, in <module>
AttributeError: 'module' object has no attribute 'run'
Would you kindly point out any error that may have crept in?
It looks to me as though we are not properly initiating the asyncio tasks.....
Thanks.
kevinkk525
Post by kevinkk525 » Tue Feb 18, 2020 9:36 pm
loop=asyncio.get_event_loop()
t1 = loop.create_task(adc_task())
t2 = loop.create_task(ds18x20_task())
loop.run_forever()
Jimmo's code would only work with the new uasyncio version which isn't implemented yet.
Kevin Köck
doceave
Post by doceave » Tue Feb 18, 2020 9:38 pm
Thanks so much Kev.... Almost midnight here in South Africa ---- this is first on my list of things to test tomorrow! :)
A super simple tutorial on implementation of this awesome feature is probably needed somewhere.
kevinkk525
Post by kevinkk525 » Tue Feb 18, 2020 9:47 pm
Kevin Köck
doceave
Post by doceave » Wed Feb 19, 2020 5:42 pm
Hi there KevinKK525 ---- I am so sorry to bother with NOOB requests.
Your modification of Jimmo's code is below:
loop.run_forever()
I have confirmed that all uasync files have been copied in the correct places on the ESP32 file system.
I am running standard MicroPython v1.12 (2019-12-20) firmware.
Uasyncio files sourced from https://github.com/micropython/micropython-lib as per PeterHinch' instructions in the tutorial you linked.
Sadly the following error results:
>>> import uasync.py
File "uasync.py", line 14, in <module>
AttributeError: 'module' object has no attribute 'get_event_loop'
Whilst not ideal, if I am able, with your help, to get just this basic example working, I am sure that I can figure the rest out myself. This example will serve as an excellent template for other tasks that would do well with a few 'await' points.
Please let me know where I can scout next for solutions to this error above....
> uPython-asyncio version incompatibility?
> Error in the example code provided?
Thanks in advance.
kevinkk525
Post by kevinkk525 » Wed Feb 19, 2020 6:25 pm
If you installed uasyncio correctly then this should not happen.
Tell me the output of:
>>> dir(asyncio)
Kevin Köck
