uasyncio --- Calling one async function from another
doceave
Post by doceave » Sun Feb 23, 2020 8:09 am
Hi there everyone
Another NOOB question relating to the uasyncio way of doing things:
In the section of code below, if I wanted to call one routine from another. The routine will execute then return a value.
I am clearly doing something incorrectly. Again I hope an expert will point out the error with a short explanation as to how to do this properly.
async def adc_right():
            ### Do things
            ### Do things
            ### Do things
            await asyncio.sleep_ms(8)
            ### Do things
            ### Do things
            ### Do things
            if index_put_R == BUFFERSIZE:
            	### How do I call the function write_ADC_log_to_file???...
            	### And get a value back from this function???
async def write_ADC_log_to_file():
            global index_put_R
            with open('ADC_log_R.csv', 'w') as ADC_log_R:
                for line in range(0, index_put_R):
                    ADC_log_R.write(str(line) + "/" + str(data_ch0_R[line]) + "/" + str(data_ch1_R[line]) + '\n')
            ### Do things
            ### return (value)
async def heater_control():
            ### Do things
            await asyncio.sleep_ms(1000)
            ### Do things
t1 = loop.create_task(adc_right())
t2 = loop.create_task(heater_control())
loop.run_forever()
Re: uasyncio --- Calling one async function from another
Post by pythoncoder » Sun Feb 23, 2020 10:54 am
This is covered in my tutorial.
If you have a coro defined with async def, there are two things you can do with it. You can (in another coro) await its completion.
async def my_coro(x):
    await asyncio.sleep(1)
    return 2*x
async def foo():
    result = await my_coro(5)  # Will pause for 1 second
    print(result)
Or you can set it running as an independent task with loop.create_task(my_coro()).
    return 2*x
async def foo():
    loop.create_task(my_coro(5))  # Immediate return (result will be lost)
    asyncio.sleep(0)
The create_task call is synchronous and returns immediately. Because it is synchronous it can be issued from synchronous code or from a coro.
doceave
Post by doceave » Sun Feb 23, 2020 3:49 pm
This is a much simpler illustration than presented in your tutorial :)
Many thanks indeed. The former examples does exactly what I need.
