ESP32, eeprom/nvs
der_kps
ESP32, eeprom/nvs
Post by der_kps » Sun Feb 23, 2020 11:04 am
I'm using ESP32 with uPython and would like to store some variables in a non-volatile storage.
There is not really an eeprom but Arduino libraries emulate EEPROM using a sector (4 kilobytes) of flash memory.
Is there any similar solution in python available?
Regards
Re: ESP32, eeprom/nvs
Post by pythoncoder » Sun Feb 23, 2020 11:13 am
MicroPython on ESP32 supports a filesystem so you can use normal Python file I/O for nonvolatile storage.
der_kps
Post by der_kps » Sun Feb 23, 2020 11:26 am
Thank's for the answer!
Do you have a link with example code to write/read 'my_var' in a nvs adress area?
Post by jimmo » Sun Feb 23, 2020 11:46 pm
The NVS on ESP32 is like a mini-filesystem. They partition the flash, and the NVS partition implements the bare minimum to support read/write of key/value pairs.
As Peter said, on MicroPython, there isn't really the same need for NVS as we already have a full filesystem which uses up the full flash.
So just regular Python code to read/write data into a file is sufficient. The simplest option is just to use json
Writing:
import json
config = {
  'name': 'value',
with f = open('config.json', 'w'):
  json.dump(config, f)
Reading:
import json
with f = open('config.json', 'r'):
  config = json.load(f)
  print(config['name'])
The other good option is to write it as a Python file that can be just imported directly, but I think the JSON option works well in the general case.
der_kps
Post by der_kps » Tue Feb 25, 2020 1:20 pm
Thanks for your json-code!
I wrote in my uPyCraft this code and pleased ;) ESP32 to execute it
import json
config = {
'my_var': 'my_val',
print(config['my_var'])
A syntax error occours: the equal-sign f = open
I would like to understand the benefit of using json.
What's going wrong?
Post by jimmo » Tue Feb 25, 2020 10:51 pm
Oh wow...sorry, somehow even after 12 years of writing Python my brain refuses write the correct syntax of the "with" statement (or the "except", but that's another story).
Anyway, what I should have written! (sorry!)
import json
config = {
  'name': 'value',
with open('config.json', 'w') as f:
import json
with open('config.json', 'r') as f:
der_kps
Post by der_kps » Fri Feb 28, 2020 3:25 pm
Hello again!
Meanwhile I've solved my problem using the filesystem peter told about.
It looks like the well known ini.file in pc-programming. :lol:
I think I've a problem what happens or should happen with json.
To store the password 1234 in a file I type the 1st line
config = {'pwd': '1234'}
The next line creates a file named config.json (or config.txt or pwd.txt ...)
An AttributeError is caused by json.dump(config, f) : object has no attribute 'dump'
Looking in the existing config.json, it's empty.
Trying to read an existing file pwd_f (made by filesystem) instead of config.json I get: object has no attribute 'load'.
As I said, what's going on? :?:
Post by jimmo » Fri Feb 28, 2020 9:12 pm
It sounds like you've replaced the json import? Maybe with a variable named json or something?
Can you try doing this at the REPL:
>>> import json
>>> json.dump
(you should get a function)
der_kps
Post by der_kps » Sat Feb 29, 2020 7:06 pm
the script I' ve posted on Sat Feb 22, 2020 7:30 pm works today :D
Don't know why, but it works and will be a much better solution to store/read 5 variables by explicit name than I did with the filesystem.
Thanks for your help and patience!
Regards
