Page 2 of 2
Re: How to adapt a python library to micropython?
Posted: Tue Mar 23, 2021 2:56 am
by sim222
aroca wrote: ↑Sun May 03, 2020 12:53 am
Hi!
I also needed MAX30100 for MicroPython, and this discussion helped a lot to implement a working script to read this sensor. I forked from the repository mentioned in the first post of this discussion, and made all needed changes. Also added a working example. Tested nicely with ESP8266.
The code is hrere:
https://github.com/rafaelaroca/max30100
Best regards, and thanks for the discussion presented here!
[]s Rafael.
WoW great post for me!!
get great idea regarding how to convert RP lib to uP lib!!
Posted: Fri May 14, 2021 7:08 pm
by electronics
Hello aroca
Hope you are doing great.
I have been working on this max30100 sensor, ESP32 & micropython for a project. I found an excellent library developed by you in micropython, which you stated that you Forked from mfitzp/max30100.
I appreciate your excellent work and efforts.
I am succeeded to upload test.py code esp32 alongside the max30100.py library. after completion of uploading it is giving some data as follows.
10064 14920
10280 15096
9872 12944
9864 12912
Here I didn't understand what is this data. from the code, I came to know that this data is (sensor.ir, sensor.red)
but I didn't understand how to get the SPO2 data and heart rate data from these values.
basically, spo2 data will be in 0% to 100% format. and Heart rate 60 to 100 beats. I want my final data to be in this format.
Please let me know how can I derive final values from raw data.
Thank you.
