How to adapt a python library to micropython?
Posted: Fri Apr 03, 2020 6:52 pm
by David128
Good morning all
I am new to the forum. I am using Micropython on an ESP8266 and ESP32. I usually develop in Python. I have a question regarding micropython library.
I'm looking for the "MAX30100" library on Micropython: I can't find it.
It exists in Python: https://github.com/mfitzp/max30100
Can I use this library? I do not think so.
Thank you
Re: How to adapt a python library to micropython?
Posted: Fri Apr 03, 2020 7:36 pm
by Roberthh
The code you refer to is for RPI. Porting that to MicroPython should be easy. It should be sufficient to replace the calls to i2c read_byte_data and write_byte_data to the matching calls of MicroPython, readfrom_mem and writeto_mem. The type of the parameters might be slightly different, but that's all.
Posted: Fri Apr 03, 2020 9:19 pm
by David128
Thank you for your information.
Posted: Sat Apr 04, 2020 10:56 am
by David128
I replaced the calls to i2c read_byte_data and write_byte_data to the matching calls of MicroPython, readfrom_mem and writeto_mem.
I also replaced this:
 # Default to the standard I2C bus on Pi.
        #self.i2c = i2c if i2c else smbus.SMBus(1)
        # To Micropython
        self.i2c = i2c
Is it correct?
I'm not sure of the import smbus!
  Library for the Maxim MAX30100 pulse oximetry system on Raspberry Pi
  Based on original C library for Arduino by Connor Huffine/Kontakt
  https: // github.com / kontakt / MAX30100
  September 2017
import smbus
INT_STATUS   = 0x00  # Which interrupts are tripped
INT_ENABLE   = 0x01  # Which interrupts are active
FIFO_WR_PTR  = 0x02  # Where data is being written
OVRFLOW_CTR  = 0x03  # Number of lost samples
FIFO_RD_PTR  = 0x04  # Where to read from
FIFO_DATA    = 0x05  # Ouput data buffer
MODE_CONFIG  = 0x06  # Control register
SPO2_CONFIG  = 0x07  # Oximetry settings
LED_CONFIG   = 0x09  # Pulse width and power of LEDs
TEMP_INTG    = 0x16  # Temperature value, whole number
TEMP_FRAC    = 0x17  # Temperature value, fraction
REV_ID       = 0xFE  # Part revision
PART_ID      = 0xFF  # Part ID, normally 0x11
I2C_ADDRESS  = 0x57  # I2C address of the MAX30100 device
PULSE_WIDTH = {
    200: 0,
    400: 1,
    800: 2,
   1600: 3,
SAMPLE_RATE = {
    50: 0,
   100: 1,
   167: 2,
   200: 3,
   400: 4,
   600: 5,
   800: 6,
  1000: 7,
LED_CURRENT = {
       0: 0,
     4.4: 1,
     7.6: 2,
    11.0: 3,
    14.2: 4,
    17.4: 5,
    20.8: 6,
    24.0: 7,
    27.1: 8,
    30.6: 9,
    33.8: 10,
    37.0: 11,
    40.2: 12,
    43.6: 13,
    46.8: 14,
    50.0: 15
def _get_valid(d, value):
        return d[value]
    except KeyError:
        raise KeyError("Value %s not valid, use one of: %s" % (value, ', '.join([str(s) for s in d.keys()])))
def _twos_complement(val, bits):
    """compute the 2's complement of int value val"""
    if (val & (1 << (bits - 1))) != 0: # if sign bit is set e.g., 8bit: 128-255
        val = val - (1 << bits)
    return val
INTERRUPT_SPO2 = 0
INTERRUPT_HR = 1
INTERRUPT_TEMP = 2
INTERRUPT_FIFO = 3
MODE_HR = 0x02
MODE_SPO2 = 0x03
class MAX30100(object):
    def __init__(self,
                 i2c=None,
                 mode=MODE_HR,
                 sample_rate=100,
                 led_current_red=11.0,
                 led_current_ir=11.0,
                 pulse_width=1600,
                 max_buffer_len=10000
        # To Micropython
        self.i2c = i2c
        self.set_mode(MODE_HR)  # Trigger an initial temperature read.
        self.set_led_current(led_current_red, led_current_ir)
        self.set_spo_config(sample_rate, pulse_width)
        # Reflectance data (latest update)
        self.buffer_red = []
        self.buffer_ir = []
        self.max_buffer_len = max_buffer_len
        self._interrupt = None
    @property
    def red(self):
        return self.buffer_red[-1] if self.buffer_red else None
    @property
    def ir(self):
        return self.buffer_ir[-1] if self.buffer_ir else None
    def set_led_current(self, led_current_red=11.0, led_current_ir=11.0):
        # Validate the settings, convert to bit values.
        led_current_red = _get_valid(LED_CURRENT, led_current_red)
        led_current_ir = _get_valid(LED_CURRENT, led_current_ir)
        self.i2c.writeto_mem(I2C_ADDRESS, LED_CONFIG, (led_current_red << 4) | led_current_ir)
    def set_mode(self, mode):
        reg = self.i2c.readfrom_mem(I2C_ADDRESS, MODE_CONFIG)
        self.i2c.writeto_mem(I2C_ADDRESS, MODE_CONFIG, reg & 0x74) # mask the SHDN bit
        self.i2c.writeto_mem(I2C_ADDRESS, MODE_CONFIG, reg | mode)
    def set_spo_config(self, sample_rate=100, pulse_width=1600):
        reg = self.i2c.readfrom_mem(I2C_ADDRESS, SPO2_CONFIG)
        reg = reg & 0xFC  # Set LED pulsewidth to 00
        self.i2c.writeto_mem(I2C_ADDRESS, SPO2_CONFIG, reg | pulse_width)
    def enable_spo2(self):
        self.set_mode(MODE_SPO2)
    def disable_spo2(self):
    def enable_interrupt(self, interrupt_type):
        self.i2c.writeto_mem(I2C_ADDRESS, INT_ENABLE, (interrupt_type + 1)<<4)
        self.i2c.readfrom_mem(I2C_ADDRESS, INT_STATUS)
    def get_number_of_samples(self):
        write_ptr = self.i2c.readfrom_mem(I2C_ADDRESS, FIFO_WR_PTR)
        read_ptr = self.i2c.readfrom_mem(I2C_ADDRESS, FIFO_RD_PTR)
        return abs(16+write_ptr - read_ptr) % 16
    def read_sensor(self):
        bytes = self.i2c.read_i2c_block_data(I2C_ADDRESS, FIFO_DATA, 4)
        # Add latest values.
        self.buffer_ir.append(bytes[0]<<8 | bytes[1])
        self.buffer_red.append(bytes[2]<<8 | bytes[3])
        # Crop our local FIFO buffer to length.
        self.buffer_red = self.buffer_red[-self.max_buffer_len:]
        self.buffer_ir = self.buffer_ir[-self.max_buffer_len:]
    def shutdown(self):
        self.i2c.writeto_mem(I2C_ADDRESS, MODE_CONFIG, reg | 0x80)
    def reset(self):
        self.i2c.writeto_mem(I2C_ADDRESS, MODE_CONFIG, reg | 0x40)
    def refresh_temperature(self):
        self.i2c.writeto_mem(I2C_ADDRESS, MODE_CONFIG, reg | (1 << 3))
    def get_temperature(self):
        intg = _twos_complement(self.i2c.readfrom_mem(I2C_ADDRESS, TEMP_INTG))
        frac = self.i2c.readfrom_mem(I2C_ADDRESS, TEMP_FRAC)
        return intg + (frac * 0.0625)
    def get_rev_id(self):
        return self.i2c.readfrom_mem(I2C_ADDRESS, REV_ID)
    def get_part_id(self):
        return self.i2c.readfrom_mem(I2C_ADDRESS, PART_ID)
    def get_registers(self):
        return {
            "INT_STATUS": self.i2c.readfrom_mem(I2C_ADDRESS, INT_STATUS),
            "INT_ENABLE": self.i2c.readfrom_mem(I2C_ADDRESS, INT_ENABLE),
            "FIFO_WR_PTR": self.i2c.readfrom_mem(I2C_ADDRESS, FIFO_WR_PTR),
            "OVRFLOW_CTR": self.i2c.readfrom_mem(I2C_ADDRESS, OVRFLOW_CTR),
            "FIFO_RD_PTR": self.i2c.readfrom_mem(I2C_ADDRESS, FIFO_RD_PTR),
            "FIFO_DATA": self.i2c.readfrom_mem(I2C_ADDRESS, FIFO_DATA),
            "MODE_CONFIG": self.i2c.readfrom_mem(I2C_ADDRESS, MODE_CONFIG),
            "SPO2_CONFIG": self.i2c.readfrom_mem(I2C_ADDRESS, SPO2_CONFIG),
            "LED_CONFIG": self.i2c.readfrom_mem(I2C_ADDRESS, LED_CONFIG),
            "TEMP_INTG": self.i2c.readfrom_mem(I2C_ADDRESS, TEMP_INTG),
            "TEMP_FRAC": self.i2c.readfrom_mem(I2C_ADDRESS, TEMP_FRAC),
            "REV_ID": self.i2c.readfrom_mem(I2C_ADDRESS, REV_ID),
            "PART_ID": self.i2c.readfrom_mem(I2C_ADDRESS, PART_ID),
Posted: Sat Apr 04, 2020 2:47 pm
by David128
In the library max30100 i replaced import smbus with:
from machine import I2C, Pin
When I run my test script ( cardio.py ), I get errors:
import max30100
from time import sleep
i2c = I2C( sda=Pin(4), scl=Pin(2), freq=20000 )
mx30 = max30100.MAX30100(i2c)
def cardio():
  mx30.read_sensor()
  # The latest value is now available by .ir
  mx30.ir
  ms30.enable_spo2()
  # The latest value is now available by .ir and .red
  mx30.ir, mx30.red
download ok
exec(open('./cardio.py').read(),globals())
  File "<string>", line 10, in <module>
  File "max30100.py", line 106, in __init__
  File "max30100.py", line 133, in set_mode
TypeError: argument has wrong type
I do not understand the error. Do you have an idea?
Thank you
Posted: Sat Apr 04, 2020 3:05 pm
by Roberthh
i2c.writeto_mem expected a buffer type argument with the data, not an integer. So you better make a local method, which packs the value into a 1 element bytearray.
in __init__, you would create:
self.xmit_data = bytearray[1]
and then you'll defene a function like:
def i2c_write(self, addr, reg, value):
    self.xmit_data[0] = value
    self.i2c.writeto_mem(addr, reg, self.xmit_data)
Then in the code, call self.i2c_write(...) instead of self.i2c.writeto_mem(...)
Posted: Sat Apr 04, 2020 6:17 pm
by David128
Thank you for your help Roberthh!
I applied your code, but i have another error message.
I despair a little.
download ok
  File "max30100.py", line 101, in __init__
  File "max30100.py", line 137, in set_mode
TypeError: 'arg' argument required
Posted: Sat Apr 04, 2020 6:22 pm
by Roberthh
Since I do not have you actual code, I guess it is the line:
It should be:
reg = self.i2c.readfrom_mem(I2C_ADDRESS, MODE_CONFIG, 1)[0]
The other lines with readfrom_mem() must be changed accordingly. I suggest reading the documentation. The chapter about I2C is here: docs.micropython.org/en/latest/library/machine.I2C.html
Posted: Sun Apr 05, 2020 8:36 pm
by David128
Thanks for your help, yes I will read the documentation.
Posted: Sun May 03, 2020 12:53 am
by aroca
Hi!
I also needed MAX30100 for MicroPython, and this discussion helped a lot to implement a working script to read this sensor. I forked from the repository mentioned in the first post of this discussion, and made all needed changes. Also added a working example. Tested nicely with ESP8266.
The code is hrere:
https://github.com/rafaelaroca/max30100
Best regards, and thanks for the discussion presented here!
[]s Rafael.
